FS Mig Welder set up - SOLD, sold, sold Buddy V, Lincoln Pro Mig 180. 220 V $500. cash |
burton73 |
Feb 9 2023, 08:00 AM
burton73 Group: Members Posts: 3,524 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
FS Mig Welder set up - Pick up only Los Angeles area
Lincoln Pro Mig 180 220 V $500. cash What you see is what you get. Argon Tank, Cart, auto dark welder’s helmet, Leather bib, Gloves, Arm protection all that you need to Mig Weld your 914 I have a pacemaker and I cannot weld anymore. You must pick this up at my shop in Inglewood California. Bob B. Works great. $500. |
Superhawk996 |
Feb 9 2023, 09:35 AM
914 Guru Group: Members Posts: 5,824 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I have a pacemaker and I cannot weld anymore. You must pick this up at my shop in Inglewood California. Bob B. Sorry to hear that. That sucks!!! Smoking deal for someone. I just used the same MiG 180 unit to weld on the plow for my tractor that had cracked. Very nice welders! Smooth wire feed. Good amperage to weld heavy 1/4” steel if needed. Can’t go wrong at that price for the welder unit, bottle and gauges, cart, PPE, helmet. This is practically a giveaway to someone within the community. |
PlantMan |
Feb 9 2023, 11:53 AM
Member Group: Members Posts: 435 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
You should be able to weld stainless with this unit, correct?
burton73 |
Feb 9 2023, 12:09 PM
mb911 |
Feb 9 2023, 12:58 PM
914 Guru Group: Members Posts: 6,851 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Yea you could weld stainless as well with the proper tri mix gas and wire.
Ps if anyone needs any welding text books to go with this I have a few that are brand new. Also this is a great deal |
Superhawk996 |
Feb 9 2023, 01:56 PM
Man - still for sale? Don’t make me drive from Idaho to LA to go get this!
burton73 |
Feb 9 2023, 04:46 PM
I have more good stuff i will be posting. Bad Boy bead blaster
Best Bob |
stownsen914 |
Feb 9 2023, 07:17 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I used a 175 amp MIG welder to do the roll cage in the racecar. You can do most anything you need on a car with a welder of this power.
bzettner |
Feb 9 2023, 07:55 PM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
(IMG:style_emoticons/default/dry.gif)
Should I be concerned? My 87 year old, mechanical engineer father has regularly MIG/TIG welded for YEARS with his fancy pacemaker! (IMG:style_emoticons/default/confused24.gif) |
76-914 |
Feb 9 2023, 08:15 PM
Yep, that is a
burton73 |
Feb 9 2023, 10:21 PM
(IMG:style_emoticons/default/dry.gif) Should I be concerned? My 87 year old, mechanical engineer father has regularly MIG/TIG welded for YEARS with his fancy pacemaker! (IMG:style_emoticons/default/confused24.gif) No sure but it says that if welding like this, the pace maker will stop paceing. My unit comes on at 39 so I will not pass out. It would be bad if I passed out just then Best Bob |
BuddyV |
Feb 10 2023, 10:47 PM
Robert Group: Members Posts: 555 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
burton73 |
Feb 11 2023, 11:06 AM
I sent you a text Sat the 11th at 9.00 am Best Bob B |
Lo-Fi Version | Time is now: 17th May 2024 - 09:18 AM |
