Bad boy bead blasting cabinet with vacuum SOLD SOLD SOLD, Must be picked up in Los Angeles $600. |
burton73 |
Feb 10 2023, 10:57 AM
burton73 Group: Members Posts: 3,526 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Must be picked up in Los Angeles $600. My shop is in Inglewood, CA So, what we have here is a Bad Boy blasting cabinet that I used at my shop for several things. It works fine but you need to do a little clean up and the front plastic panel has some frosting even though I had used thin clear mylar protection tear offs. You could just unscrew the panel and put glass in place of the plastic. It could use more light inside and I just used to put a spotlight in through the door and plug it in 110. I removed the pressure control because I just had all that I could get from the compressor. No Biggy if you want to change back. I just plug in direct with a quick air fitting. note the foot switch. Same pallet that it came to my shop on As with all blasters you need dry air and a bigger compressor to get the job done faster. I used a 80 gallon tank with a 5 hp 2 stage pump. Thank you for looking Bob B |
Feb 10 2023, 02:09 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
That’s a good price. We have one from that company and it cost a lot.
Aerostatwv |
Feb 10 2023, 03:54 PM
Member Group: Members Posts: 117 Joined: 13-July 11 From: WV Member No.: 13,315 Region Association: MidAtlantic Region |
Wow! That is a deal...
Aerostatwv |
Feb 10 2023, 03:55 PM
Sorry for the 2 posts..
How do you delete a post? |
markhoward |
Feb 10 2023, 04:15 PM
Member Group: Members Posts: 377 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
I’m popping on it..
burton73 |
Feb 10 2023, 04:31 PM
Lo-Fi Version | Time is now: 21st May 2024 - 12:29 AM |
