Bad boy bead blasting cabinet with vacuum
Must be picked up in Los Angeles $600. My shop is in Inglewood, CA
So, what we have here is a Bad Boy blasting cabinet that I used at my shop for several things.
It works fine but you need to do a little clean up and the front plastic panel has some frosting even though I had used thin clear mylar protection tear offs. You could just unscrew the panel and put glass in place of the plastic. It could use more light inside and I just used to put a spotlight in through the door and plug it in 110. I removed the pressure control because I just had all that I could get from the compressor. No Biggy if you want to change back. I just plug in direct with a quick air fitting. note the foot switch. Same pallet that it came to my shop on
As with all blasters you need dry air and a bigger compressor to get the job done faster. I used a 80 gallon tank with a 5 hp 2 stage pump.
Thank you for looking
Bob B
Click to view attachment Click to view attachment
Click to view attachmentClick to view attachment
