| mb911 |
Feb 11 2023, 08:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,756 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
I am offering a spring sale on oil tank, filler neck, filter console, engine sheet metal. This makes the conversions much more budget minded. $1200 for everything shipped. There maybe delays in shipping depending on what is inventory at the time of order.
Engine sheet metal is much improved over the original sets but I encourage everyone to fit and trim as needed prior to painting. Now to the oil tanks. These are far superior to the oem tanks as they are both vertically and horizontally baffled to eliminate air in the oil and to help with sloshing in the tank. They are made of .090 5052 aluminum and are all pressure tested prior to shipping. No rusting takes place with these tanks and allow for either metric or AN fittings to be used. Filter consoles are anodized aluminum and use the oc54 oil filter like the 74-89 911 and eliminates the need for bypass that gets gummed up on the factory consoles |
| mb911 |
Feb 11 2023, 08:49 AM
| SirAndy |
Feb 11 2023, 10:53 AM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,479 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
@mb911
Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) |
| sixnotfour |
Feb 11 2023, 11:00 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,213 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
@mb911 Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/beerchug.gif) great improvement...so many 911 owners rely on this feature.. |
| mb911 |
Feb 11 2023, 11:46 AM
@mb911 Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) Andy do you have a sensor? I could play with it for sure. I always thought it would be cool as well |
| burton73 |
Feb 11 2023, 12:32 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 4,002 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
@mb911 Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) Andy do you have a sensor? I could play with it for sure. I always thought it would be cool as well Andy and Ben, This is my set up on #41. It was put in in the 70s but for wiring questions you could ask Eric at PMB as re refinished the tank during the complete restoration and obviously put it in the car. Best Bob B ![]() |
| SirAndy |
Feb 11 2023, 02:21 PM
@mb911 Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) Andy do you have a sensor? I could play with it for sure. I always thought it would be cool as well I don't remember the exact year for my 911 gauges and i don't have a sensor. But i can get you the gauge part number later. Should be able to match that to a sensor. (IMG:style_emoticons/default/smile.gif) |
| mb911 |
Feb 11 2023, 07:28 PM
@mb911 Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) Andy do you have a sensor? I could play with it for sure. I always thought it would be cool as well I don't remember the exact year for my 911 gauges and i don't have a sensor. But i can get you the gauge part number later. Should be able to match that to a sensor. (IMG:style_emoticons/default/smile.gif) I am sure I could make it to work |
| ClayPerrine |
Feb 11 2023, 08:21 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
| SirAndy |
Feb 13 2023, 11:54 PM
@mb911 Andy do you have a sensor? I could play with it for sure. I always thought it would be cool as wellIs there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) But i can get you the gauge part number later. Should be able to match that to a sensor. (IMG:style_emoticons/default/smile.gif) Gauge # 911.641.202.29 ![]() |
| billh1963 |
Feb 14 2023, 03:12 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
Oil level would be a great feature!
| mb911 |
Feb 23 2023, 05:21 PM
Still available. I would also figure out a oil level is some one provides a sensor and be very reasonable.
| NARP74 |
Feb 23 2023, 05:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
Need one pulled from a stock 911 oil tank right? I don't have one, but that is the only gauge I have that does not work and I have a bunch of gauges.
| SirAndy |
Feb 23 2023, 05:59 PM
I would also figure out a oil level is some one provides a sensor and be very reasonable. @mb911 I just bought one off ebay, please PM me with details on where to send it. (IMG:style_emoticons/default/beerchug.gif) |
| nditiz1 |
Feb 23 2023, 08:00 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,272 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region
Wait if you have that in the left spot where is your temp and oil pressure?
| Chris H. |
Feb 27 2023, 08:06 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,082 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
| SirAndy |
Feb 27 2023, 09:04 PM
Wait if you have that in the left spot where is your temp and oil pressure? 911 style 5-gauge cluster (IMG:style_emoticons/default/shades.gif) |
| mb911 |
Apr 23 2023, 05:44 PM
Still have some of these available. Sir Andy I never got the sender from you. Not sure where you sent it?
| Dr Evil |
Apr 23 2023, 07:40 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Id be interested in gauge sensor option. Have to sell current tank (IMG:style_emoticons/default/smile.gif)
| Root_Werks |
Apr 23 2023, 08:26 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,964 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
@mb911 Is there any way you can think of to make a 911 oil level sender work with your tank design? The one thing that has bothered me ever since i did the conversion some 15 years ago is the non working 911 oil level gauge in my gauge cluster. If you can make it work, i'd be happy to pay extra for the r&d. (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/beerchug.gif) great improvement...so many 911 owners rely on this feature.. (IMG:style_emoticons/default/agree.gif) My current six conversion has a factory six oil tank. Would gladly ditch it for a tank with level sender |
Lo-Fi Version | Time is now: 30th April 2026 - 01:22 PM |
