New Engine tin source? |
tshih914 |
Feb 12 2023, 06:00 AM
Member Group: Members Posts: 79 Joined: 17-July 05 From: central NJ Member No.: 4,426 |
I am starting to reassemble my 1975 2L engine after tearing it apart 20 years ago. As it has been a long while since I started the teardown, I don't remember where and what all the pieces are. It would be awesome if anyone would send/post me a photo showing all the pieces and where they go (of the complete engine tins). Even better if anyone could tell me if a source of aftermarket engine tins can be found.
Thanks in advance, Tom |
JeffBowlsby |
Feb 12 2023, 07:14 AM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
New Carbon fiber tin is available but it’s $$$$$
brant |
Feb 12 2023, 07:46 AM
914 Wizard Group: Members Posts: 11,615 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Buy a Haynes manual
zoomCat |
Feb 12 2023, 09:57 AM
Member Group: Members Posts: 160 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
914werke |
Feb 12 2023, 12:09 PM
"I got blisters on me fingers" Group: Members Posts: 10,027 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
No source for new. Best is to figure out what you have & fill in the missing.
Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) |
930cabman |
Feb 12 2023, 03:09 PM
Advanced Member Group: Members Posts: 3,002 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
There is plenty of old stuff floating around, might need to move the location of the spark plug holes if 1.8 top tin is all that's readily available
Good luck with the build, will she be stock? |
r_towle |
Feb 12 2023, 04:43 PM
Custom Member Group: Members Posts: 24,569 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Superhawk996 |
Feb 12 2023, 04:52 PM
914 Guru Group: Members Posts: 5,760 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
New Carbon fiber tin is available but it’s $$$$$ Who sells that? Rich Hit the lottery? Don’t forget us! https://lnengineering.com/raby-s-aircooled-...ne-tin-kit.html |
914werke |
Feb 12 2023, 05:01 PM
QUOTE "are not plug and play as the bolt and screw holes are not pre-drilled on the shrouds and will have to be added during the installation process" For that princely sum you'd thinks they were complete & delivered wrapped in silk (IMG:style_emoticons/default/biggrin.gif) |
r_towle |
Feb 12 2023, 06:02 PM
I can’t imagine brand new steel would be cheaper
bkrantz |
Feb 12 2023, 08:21 PM
914 Guru Group: Members Posts: 7,737 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
And think of the enormous weight savings!
cgnj |
Feb 12 2023, 10:13 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
QUOTE "are not plug and play as the bolt and screw holes are not pre-drilled on the shrouds and will have to be added during the installation process" For that princely sum you'd thinks they were complete & delivered wrapped in silk (IMG:style_emoticons/default/biggrin.gif)And installed To op Find cylinder head tin Part 1&2 I'm local and can help you with the other pieces |
CCE |
Feb 13 2023, 08:48 AM
CCE Group: Members Posts: 309 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
If money is not an issue.make it carbon fiber…
VaccaRabite |
Feb 13 2023, 09:06 AM
En Garde! Group: Admin Posts: 13,426 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach |
tshih914 |
Feb 15 2023, 05:55 PM
There is plenty of old stuff floating around, might need to move the location of the spark plug holes if 1.8 top tin is all that's readily available Good luck with the build, will she be stock? The engine is going to be stock except for minor modifications to 1974 specs (delete air pump from 1975 CA emission). I will look for the parts which have been moved over the years. I have purchased a new cam shaft that's NOS and have put in the stronger con rod bolts. Waiting for Andrade Tabari to modify my valve train to accept 10 mm swivel feet rockers. |
tshih914 |
Feb 15 2023, 05:58 PM
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach Thanks for the heads up. Those pieces are what I was looking for and as I recalled they go at the bottom of the cylinders above the pushrod tubes. |
tshih914 |
Feb 15 2023, 06:34 PM
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach Thanks for the heads up. Those pieces are what I was looking for and as I recalled they go at the bottom of the cylinders above the pushrod tubes. Found a box containing piece #1 and 27 in addition to the alternator and piece of the fuel rail. Attached thumbnail(s) |
TJB/914 |
Feb 15 2023, 06:41 PM
Mid-Engn. Group: Members Posts: 4,326 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach Thanks for the heads up. Those pieces are what I was looking for and as I recalled they go at the bottom of the cylinders above the pushrod tubes. Found a box containing piece #1 and 27 in addition to the alternator and piece of the fuel rail. tshih914 I think I have some of the lower tin pieces that's off a 1974 1.8 motor. Question from the experts? Is i.8 tin the same as 2.0?? Tom |
tshih914 |
Feb 15 2023, 06:47 PM
No source for new. Best is to figure out what you have & fill in the missing. Since many of the parts were shared with the T2 motor there is no need to reproduce them. Unless you have $ to burn & are looking for the Bling effect... I understand that The T4 store has CF units? BTW I just posted this shortly ago to a similar request (IMG:style_emoticons/default/rolleyes.gif) When you put the tin back on REMEMBER, pieces 5 and 5a need to go on before the pushrod tubes are installed. I don't think you can install them with the tubes installed. Often they are just left on the motor. Zach Thanks for the heads up. Those pieces are what I was looking for and as I recalled they go at the bottom of the cylinders above the pushrod tubes. Found a box containing piece #1 and 27 in addition to the alternator and piece of the fuel rail. The fuel rail at one end a part was cut off. Is that the fuel pressure regulator? Attached thumbnail(s) |
Krieger |
Feb 15 2023, 07:03 PM
Advanced Member Group: Members Posts: 4,704 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
That is your air injection system. The one way valve is cut. This is smog equipment. It looks like the air pump that feeds it is in the box below it.
Lo-Fi Version | Time is now: 29th April 2024 - 01:24 AM |
