Brake Fluid Leaking at Plastic Reservoir, The fluid is leaking where the rubber coupler connects to plastic line |
tjgalvin |
Feb 14 2023, 03:29 PM
Newbie Group: Members Posts: 28 Joined: 17-September 20 From: Asheville, NC Member No.: 24,699 Region Association: South East States |
I have been fighting a new MC from 914Rubber. I put it on the bench last night with output ports plugged and the reservoir connected with vinyl tubes in the MC grommets and a fuel line rubber tube pressed on the reservoir. No leaks overnight.
I installed the MC in the car with the output ports plugged. I used fuel hose on the plastic tube with hose clamps and pressed the fuel hose over the reservoir ports. Leak was detected where the fuel hose was attached to the plastic tube. So, where do I get official blue hose for the reservoir to plastic tube adapter? I thought I saw it someplace, but I can't remember where. Thanks for any help in sourcing the hose. Tim |
Lo-Fi Version | Time is now: 19th May 2024 - 11:19 AM |
