F:S Undamaged Rear Window Defogger Wiringg Complete |
edrotol |
Feb 14 2023, 06:51 PM
edrotol Group: Members Posts: 190 Joined: 23-April 06 From: Woburn, MA Member No.: 5,910 Region Association: North East States |
cgnj |
Feb 14 2023, 07:09 PM
Senior Member Group: Members Posts: 623 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Try reading the classified rules. Stop spamming.
theer |
Feb 14 2023, 10:57 PM
Senior Member Group: Members Posts: 676 Joined: 31-July 15 From: Dover, MA Member No.: 19,014 Region Association: North East States |
Carlos- cool your jets, man.
I have personally dealt with Ed and can vouch for him. He’s a great guy and local to me. His stuff is top-shelf. |
jim_hoyland |
Feb 15 2023, 06:38 PM
Get that VIN ? Group: Members Posts: 9,303 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
And, another possibility: I used that same window-defrost harness for my heated seats. It’s a perfect set up….. (IMG:style_emoticons/default/smile.gif) it’s been in use for 10+ years too
DC_neun_vierzehn |
Feb 15 2023, 11:19 PM
Member Group: Members Posts: 378 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
And, another possibility: I used that same window-defrost harness for my heated seats. It’s a perfect set up….. (IMG:style_emoticons/default/smile.gif) it’s been in use for 10+ years too @jim_hoyland do tell us more about this set up pls : ) |
jim_hoyland |
Feb 16 2023, 04:29 PM
And, another possibility: I used that same window-defrost harness for my heated seats. It’s a perfect set up….. (IMG:style_emoticons/default/smile.gif) it’s been in use for 10+ years too @jim_hoyland do tell us more about this set up pls : ) The switch goes into the front panel. The 12v power and ground wires attach to the posts at the front of the relay board; there is a special connector that fits over the two posts. The output wited go to the seat heater. Only difference is I’m not using it as a defrost circuit. It’s a very clean set up and saves a ton of time making up a harnes, plus you get power directly from the relay board. Attached thumbnail(s) |
914werke |
Feb 16 2023, 04:53 PM
"I got blisters on me fingers" Group: Members Posts: 10,082 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/cheer.gif) Im gonna steal that one.
rjames |
Feb 16 2023, 05:24 PM
I'm made of metal Group: Members Posts: 3,933 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
And, another possibility: I used that same window-defrost harness for my heated seats. It’s a perfect set up….. (IMG:style_emoticons/default/smile.gif) it’s been in use for 10+ years too You need heated seats in Cali? (IMG:style_emoticons/default/poke.gif) |
jim_hoyland |
Feb 16 2023, 05:51 PM
And, another possibility: I used that same window-defrost harness for my heated seats. It’s a perfect set up….. (IMG:style_emoticons/default/smile.gif) it’s been in use for 10+ years too You need heated seats in Cali? (IMG:style_emoticons/default/poke.gif) Sometimes it gets pretty cold; then, there the soothing heat on the back…,., |
DC_neun_vierzehn |
Feb 16 2023, 06:19 PM
And, another possibility: I used that same window-defrost harness for my heated seats. It’s a perfect set up….. (IMG:style_emoticons/default/smile.gif) it’s been in use for 10+ years too @jim_hoyland do tell us more about this set up pls : ) The switch goes into the front panel. The 12v power and ground wires attach to the posts at the front of the relay board; there is a special connector that fits over the two posts. The output wited go to the seat heater. Only difference is I’m not using it as a defrost circuit. It’s a very clean set up and saves a ton of time making up a harnes, plus you get power directly from the relay board. That’s genius. I’ve never had a could bum in my 914 though. Even in cool weather, if I throw on the heat, I have to crack the windows. Car is garage kept so it’s never at an outdoor temp. And here in the mid-Atlantic, once they put salt down the first time it’s game over until spring. But I wish I had a need for this idea bc I love it that much. |
Lo-Fi Version | Time is now: 21st May 2024 - 12:47 AM |
