QUOTE(jim_hoyland @ Feb 16 2023, 05:29 PM)
QUOTE(DC_neun_vierzehn @ Feb 15 2023, 09:19 PM)
QUOTE(jim_hoyland @ Feb 15 2023, 07:38 PM)
And, another possibility: I used that same window-defrost harness for my heated seats. It’s a perfect set up…..
it’s been in use for 10+ years too
@jim_hoyland do tell us more about this set up pls : )
The switch goes into the front panel. The 12v power and ground wires attach to the posts at the front of the relay board; there is a special connector that fits over the two posts.
The output wited go to the seat heater. Only difference is I’m not using it as a defrost circuit.
It’s a very clean set up and saves a ton of time making up a harnes, plus you get power directly from the relay board.
That’s genius.
I’ve never had a could bum in my 914 though. Even in cool weather, if I throw on the heat, I have to crack the windows. Car is garage kept so it’s never at an outdoor temp. And here in the mid-Atlantic, once they put salt down the first time it’s game over until spring.
But I wish I had a need for this idea bc I love it that much.
