| Al Meredith |
Mar 1 2023, 10:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 981 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I am installing a 914 engine into a 356 (a 1973 or 74) I bought the 914 to bug kit from The 914 Store (LN ENGINEERING ) but I have been told the 356 transmission is different and the 356 starter ring may not match. The 200 MM PP may not fit. HELP ! Al
| r_towle |
Mar 1 2023, 12:48 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I am installing a 914 engine into a 356 (a 1973 or 74) I bought the 914 to bug kit from The 914 Store (LN ENGINEERING ) but I have been told the 356 transmission is different and the 356 starter ring may not match. The 200 MM PP may not fit. HELP ! Al I would suggest 356registry.org If not, pm me and send me your email I will hook you up to a buddy who knows all about 356, and those you need to ask. |
| rhodyguy |
Mar 1 2023, 01:18 PM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Jake Raby would know.
| Al Meredith |
Mar 1 2023, 04:51 PM
I've already spoken to Jake we plan to get together , he has the parts to show me .
| r_towle |
Mar 1 2023, 07:06 PM
Rough answer,
The difference is the starter motor teeth, you may need to convert to 12 volts to make it work. Rod Emory has one he just did….just seen by a friend, it does work, provided you use the vw flywheel and 12 vdc starter . Again, rough answer |
| sixnotfour |
Mar 1 2023, 07:35 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,060 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains
Rough answer, The difference is the starter motor teeth, you may need to convert to 12 volts to make it work. Rod Emory has one he just did….just seen by a friend, it does work, provided you use the vw flywheel and 12 vdc starter . Again, rough answer vw use a 914 starter, dont know 356 |
| sixnotfour |
Mar 2 2023, 06:48 PM
and will have to grind bel housing for 12 volt starter ring gear..
Lo-Fi Version | Time is now: 7th December 2025 - 03:17 PM |
