Windshield wiper motor replacement, How do I disconnect the wiring? |
maxwelj |
Mar 3 2023, 02:43 PM
rebuilt member Group: Benefactors Posts: 278 Joined: 8-January 04 From: Owasso, OK Member No.: 1,532 Region Association: None |
I’m trying to repair/replace the windshield wiper motor in my -6. Does the wiring harness need to be disconnected under the dash, or is there a way do disconnect it at the motor?
Thanks for any hints. |
ClayPerrine |
Mar 3 2023, 02:51 PM
Life's been good to me so far..... Group: Admin Posts: 15,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I’m trying to repair/replace the windshield wiper motor in my -6. Does the wiring harness need to be disconnected under the dash, or is there a way do disconnect it at the motor? Thanks for any hints. The wiper harness is mated to the motor, and has a grommet like plug in the body, plus one power wire and 1 ground point. You have to pull the grommet out of the body to replace the motor. |
maxwelj |
Mar 4 2023, 10:55 AM
When we pull the grommet from the trunk side of the bulkhead, it disconnects the harness? Just don’t want to do any damage to the harness. |
ClayPerrine |
Mar 5 2023, 07:31 PM
fixer34 |
Mar 6 2023, 07:22 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
When we pull the grommet from the trunk side of the bulkhead, it disconnects the harness? Just don’t want to do any damage to the harness. There is no harness, just the wiring that goes to the wiper switch. You can pull out the speedo, reach in and unplug it. It's been a while, but I don't remember having to disconnect the wiper motor wires all the way back to the column/switch. I thought there was an inline connector around the bulkhead. (?) |
Lo-Fi Version | Time is now: 14th May 2024 - 10:24 PM |
