I’m trying to repair/replace the windshield wiper motor in my -6. Does the wiring harness need to be disconnected under the dash, or is there a way do disconnect it at the motor? Thanks for any hints.
ClayPerrine
Mar 3 2023, 02:51 PM
QUOTE(maxwelj @ Mar 3 2023, 02:43 PM)
The wiper harness is mated to the motor, and has a grommet like plug in the body, plus one power wire and 1 ground point. You have to pull the grommet out of the body to replace the motor.
maxwelj
Mar 4 2023, 10:55 AM
When we pull the grommet from the trunk side of the bulkhead, it disconnects the harness? Just don’t want to do any damage to the harness.
ClayPerrine
Mar 5 2023, 07:31 PM
QUOTE(maxwelj @ Mar 4 2023, 10:55 AM)
There is no harness, just the wiring that goes to the wiper switch.
You can pull out the speedo, reach in and unplug it.
fixer34
Mar 6 2023, 07:22 PM
QUOTE(ClayPerrine @ Mar 5 2023, 07:31 PM)
It's been a while, but I don't remember having to disconnect the wiper motor wires all the way back to the column/switch. I thought there was an inline connector around the bulkhead. (?)
