Back into 914 world, various topics |
brant |
Mar 12 2023, 11:09 AM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Previous is what I meant to type
An old previous post from about 15 years ago Fat fingers |
wjpierce |
Mar 12 2023, 11:39 AM
Newbie Group: Members Posts: 15 Joined: 2-December 07 From: Lompoc, ca Member No.: 8,407 |
[quote name='brant' date='Mar 12 2023, 08:47 AM' post='3064510']
I remember this car from a devious thread about 15 years back I run in vintage wheel to wheel and also run a rear sway bar. (Upsized from stock) I am curious as to how you mounted the rear sway bar. Pelican has a kit that requires welding the mount with a reinforcement in the trunk, I think but I was wondering about bolt in brackets mainly because I am not a good (I'm really bad) welder. I, too am curious about the devious post!!!!!! |
brant |
Mar 12 2023, 11:48 AM
On my street car weld in mounts
On my race car… fabricated weld in mounts to fit an aftermarket bar Attached thumbnail(s) |
TROJANMAN |
Mar 12 2023, 11:53 AM
Looks nice in pictures......... Group: Members Posts: 5,271 Joined: 5-March 04 From: Colorado Member No.: 1,753 Region Association: None |
what are all of those holes? (IMG:style_emoticons/default/laugh.gif)
76-914 |
Mar 12 2023, 11:54 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Welcome back. If this is what you refer to using for the rear sway bar mounts, it is not enough by itself. You need to weld in an opposing piece of 1/8" that is slightly larger overall to sandwich the trunk floor. Otherwise the trunk floor will begin to have stress cracks. I just corrected that on mine a few months back. (IMG:style_emoticons/default/beerchug.gif) https://www.pelicanparts.com/More_Info/RRSW...amp;SVSVSI=0719
wjpierce |
Mar 13 2023, 08:27 AM
[quote name='76-914' date='Mar 12 2023, 10:54 AM' post='3064536']
Welcome back. If this is what you refer to using for the rear sway bar mounts, it is not enough by itself. You need to weld in an opposing piece of 1/8" that is slightly larger overall to sandwich the trunk floor. Otherwise the trunk floor will begin to have stress cracks. I just corrected that on mine a few months back. (IMG:style_emoticons/default/beerchug.gif) https://www.pelicanparts.com/More_Info/RRSW...amp;SVSVSI=0719 Yes, thanks to all for the sway bar pictures. Pelican recommends reinforcement of the floor for that very reason. Based on the position, it looks like some sort of welded arrangement plus reinforcement is the best. It's been years since I repaired the Hell hole on my previous car. Back to YouTube I guess. Thanks again. |
Lo-Fi Version | Time is now: 9th June 2024 - 01:18 PM |
