Settled - Side Valences are affixed with plastic button head rivets, 'Rocker panel' rivets |
JeffBowlsby |
Mar 11 2023, 01:15 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
We know of two docmented original 914s, both have side valances attached with plastic buttonhead rivets, not aluminum rivets.
Black rivets for cars with black valances Clear rivets for the 1974 LE cars with the yellow or orange valances PET also only lists the plastic button head rivets. All the photos of 914s with aluminum rivets are not original, are commonly available and have been replaced at some point. Thanks to George Hussey, Steve Gaglione (2nd owner of very orignal Sahara Beige) and Alberto Favilla (original owner) and to Rich Daunhauer (914Werke) for their knowledge. Attached thumbnail(s) Attached image(s) |
rgalla9146 |
Mar 11 2023, 08:26 PM
Advanced Member Group: Members Posts: 4,547 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Late cars with black plastic thresholds had black plastic expanding rivets.
The same black rivets were used on black rocker covers. Early cars with aluminum thresholds had off-white plastic expanding rivets. All early cars had the same off-white plastic expanding rivet on the black rockers. Clear plastic expanding rivets were never original on a 914 .....but they may have been supplied later by Porsche as a repair part. Aluminum rivets were never original on a 914 Back in the old days original rocker rivets could be removed and re-installed if done with care. If the rivet was not brittle the center pin can be pushed through and retreived from below. The rivet could then be lifted out of the panel and later re-installed. If this method was used on the rivets near the inner door seal the pin of the rivet would be lost inside the longitudinal. Way in the past I retrieved many from parts cars and reused them. No correct replacements for early cars were available in those days. LE rockers ? |
Lo-Fi Version | Time is now: 7th May 2024 - 03:35 AM |
