Settled - Side Valences are affixed with plastic button head rivets, 'Rocker panel' rivets |
JeffBowlsby |
Mar 11 2023, 01:15 PM
914 Wiring Harnesses Group: Members Posts: 8,490 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
We know of two docmented original 914s, both have side valances attached with plastic buttonhead rivets, not aluminum rivets.
Black rivets for cars with black valances Clear rivets for the 1974 LE cars with the yellow or orange valances PET also only lists the plastic button head rivets. All the photos of 914s with aluminum rivets are not original, are commonly available and have been replaced at some point. Thanks to George Hussey, Steve Gaglione (2nd owner of very orignal Sahara Beige) and Alberto Favilla (original owner) and to Rich Daunhauer (914Werke) for their knowledge. Attached thumbnail(s) Attached image(s) |
Van B |
Mar 12 2023, 02:21 PM
Senior Member Group: Members Posts: 1,582 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
With galvanic corrosion, aluminum will lose out over low carbon steel. That’s why bolts going into aluminum engines are zinc plated. Zinc acts as the sacrificial anode giving up its electrons more easily.
Hole diameter is 3.4mm for both threshold and rocker. I just measured for you @Montreal914 |
Lo-Fi Version | Time is now: 7th May 2024 - 05:13 PM |
