| shag |
Mar 13 2023, 01:19 PM
Member ![]() ![]() Group: Members Posts: 99 Joined: 18-January 14 From: mount wolf pa Member No.: 16,901 Region Association: North East States
Help, my ignition switch will not turn. I can install and remove key. After I jiggled the key the buzzer sounded because the door was open but I still could not turn the key. I would like to keep the original key and just repair the switch if I can but how do I repair this?
| Robarabian |
Mar 13 2023, 01:30 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 739 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
Maybe you have a stuck wafer in the lock...
You can either remove it and inspect and clean and re-lube or Just try to lube it up with a lubricant that is not one that attracts and holds dirt / crud... dont drench it in other words. Maybe start with some light lube on the key itself and work it around gently. I know others will chime in, but I would start there. Help, my ignition switch will not turn. I can install and remove key. After I jiggled the key the buzzer sounded because the door was open but I still could not turn the key. I would like to keep the original key and just repair the switch if I can but how do I repair this? |
| shag |
Mar 13 2023, 01:36 PM
You think If I just put a bunch of dry lubricant on the key and wiggle it around a while that may solve the problem. Ok I will try that first. It cannot hurt anything! Thanks for your input.
| mihai914 |
Mar 13 2023, 01:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None
Just wait a little, there is a member here who rebuilds locks sets and has a lot of expertise.
I think he doesn't recommend using dry lubricant. @thecabinetmaker |
| shag |
Mar 13 2023, 01:47 PM
Ok, I just returned from the garage and I don't have any dry lubricant. Read your post and I will not do anything until I hear from the person you are referring to. Thanks to everyone.
| r_towle |
Mar 13 2023, 02:02 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Have you wiggled the steering wheel to take the pressure off the key(rotation) lock?
It may be sitting wierd. There are also “how to” threads and articles showing how to remove the switch and cylinder, it’s not terribly complicated. Or Cabinetmaker |
| shag |
Mar 13 2023, 02:33 PM
r towle, That was it!!! I know I had this problem years ago but have forgotten about it. Thanks very much I greatly appreciate all the help from everyone.
| euro911 |
Mar 13 2023, 02:39 PM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
Have you wiggled the steering wheel to take the pressure off the key(rotation) lock? It may be sitting wierd. There are also “how to” threads and articles showing how to remove the switch and cylinder, it’s not terribly complicated. Or Cabinetmaker (IMG:style_emoticons/default/agree.gif) |
| shag |
Mar 13 2023, 03:19 PM
Mihai, I would like to ask the individual you are talking about if there is there a lubricant that should be used to keep the switch from doing this again and to keep its longevity?
| StarBear |
Mar 13 2023, 03:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,242 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Mihai, I would like to ask the individual you are talking about if there is there a lubricant that should be used to keep the switch from doing this again and to keep its longevity? (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/biggrin.gif) |
| r_towle |
Mar 13 2023, 04:15 PM
If you take one apart you will see the key cylinder is locked in position by the little tumblers that properly retract when you put the key in place, no lube required.
Then you are simply turning an electrical switch, which should never be lubricated. The steering wheel lock is a 1/4 in pin that drops into place ….that can need help moving and in some cases it will not move if sideways pressure is pushing on it. Wiggling the steering wheel can remove that pressure. Pulling the wheel to one side or the other while trying to turn the key can also help. |
| GregAmy |
Mar 13 2023, 04:22 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,647 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
This is NOT a "dis" to the OP...seriously, it's not.
This is an old-guy rant (with cane pointed at clouds) about how our steering shafts have always (well, since around '69/'70) been locked with a pin/shaft extending from the manual lock cylinder into the steering shaft so that the car could not be stolen if it was hot-wired, because the perp could not turn the steering lock. So you had to relieve that friction from the shaft so that you could turn the pin with the key. I mean, I thought EVERYONE* knew this...! To the OP: you're driving a manual transmission car. I salute you. Go forth and multiply. I'm going back to my Geritol (you can look it up). - GA *Well, GenX and beyond... |
| Osnabruck914 |
Mar 13 2023, 05:48 PM
Member ![]() ![]() Group: Members Posts: 206 Joined: 19-December 22 From: United States Member No.: 27,038 Region Association: South East States |
Once again r_towle has the answer. He has given great advice time and time again over the years and should be put in the 914World Hall of Fame if Sir Andy ever creates one. I know he's helped me many times in my former life as username "Ansbacher".
Osnabruck914 (Ansbacher) |
| shag |
Mar 13 2023, 07:52 PM
I would like to thank you all for your comments and help, especially r_rowle for his insight to my negligible knowledge of the switch.
| technicalninja |
Mar 13 2023, 08:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,531 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region
A bunch of new cars no longer have the steering lock.
If you don't have the steering lock something else has to lock... Transmission and parking brake locks are a thing now. I FAR prefer the steering locks over the others. It's gotten far more complex and difficult to repair the auto lock crap. The parking brake locks are the worst IMO. Lots of cars have fully electric door locks now as well. You get a weird electrical problem, and you cannot open the doors. When you send a wrecker to pick it up sometimes they have to DRAG it onto the flat bed. Modern solutions to an old problem make an auto technicians job harder. Don't diss the steering lock. At least this system was purely mechanical. I've had to crawl under cars to hook up a jump box to either the alternator or starter lug multiple times in the past year. Stupidity... |
| mihai914 |
Mar 14 2023, 06:35 AM
Mihai, I would like to ask the individual you are talking about if there is there a lubricant that should be used to keep the switch from doing this again and to keep its longevity? @shag You can read this short thread that talks about lubricating the locks. http://www.914world.com/bbs2/index.php?sho...=363475&hl= TheCabinetmaker is the member I was talking about. |
| shag |
Mar 14 2023, 03:21 PM
Hello Mihai, Thanks for the good reading material. I must get some of that stuff!
| TheCabinetmaker |
Mar 14 2023, 06:57 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,367 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Glad you got it sorted! Rich is usually on the money! After 50 years the ignitions get gummed up and need a good cleaning and relubing. I provide this service, or you can do it yourself with some patience and are good with handling very small items.
| shag |
Mar 15 2023, 09:15 AM
Thanks to all and for not making me feel like the dumbass that I am. R_towle are you going to attend the Carlisle Show? If so please let me know. I would like to meet you. I will be there Friday night for the 914 run and all day Saturday.
Lo-Fi Version | Time is now: 16th March 2026 - 09:34 PM |
