What went wrong?, it was running great and then not at all |
Type 47 |
Mar 15 2023, 03:59 PM
Senior Member Group: Members Posts: 781 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
so we put the original 62k engine back in that had not had the distributor removed. Adjusted the valves (again after we put about 10 miles on it) we rebuilt the Webbers and it fired up. We did some timing and tweaking on the carbs.
It ran OK but a little shy of perfect. I replaced the wires and it seemed to improve it but idled a little high around 1,200. My son came over to work on it the next day, but I wasn't home. All of a sudden, it won't even run. we swapped distributers (both 009's) with the parts car, then swapped points (adjusted to 0.016). no improvement. tested spark to all four cylinders. I seems like it's really out of timing but we didn't change it much. (except for the fact that we took the distributor out) my son says we have spark, too much fuel, and not enough air. What do we do next????? |
Superhawk996 |
Mar 15 2023, 04:15 PM
914 Guru Group: Members Posts: 5,778 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
we swapped distributers (both 009's) with the parts car, then swapped points (adjusted to 0.016). no improvement. tested spark to all four cylinders. I seems like it's really out of timing but we didn't change it much. (except for the fact that we took the distributor out) Not trying to be a jerk but saying you didn’t change much right after mentioning a distributor swap doesn’t make sense. Timing is 100% dependent on the distributor and its position. If you’re convinced distributor is installed correctly and plug wires are in proper firing order . . . Statically time the car then see if it starts. |
Type 47 |
Mar 15 2023, 04:21 PM
we swapped distributers (both 009's) with the parts car, then swapped points (adjusted to 0.016). no improvement. tested spark to all four cylinders. I seems like it's really out of timing but we didn't change it much. (except for the fact that we took the distributor out) Not trying to be a jerk but saying you didn’t change much right after mentioning a distributor swap doesn’t make sense. Timing is 100% dependent on the distributor and its position. If you’re convinced distributor is installed correctly and plug wires are in proper firing order . . . Statically time the car then see if it starts. you're not being a jerk...I probably didn't explain properly. 6 weeks ago when we put the engine back in we had not touched the distributor. It ran ok, then we began to dial it in. Today, we swapped distributor, points, etc. trying to figure out why it went south. |
Lo-Fi Version | Time is now: 5th May 2024 - 04:26 AM |
