What went wrong?, it was running great and then not at all |
Type 47 |
Mar 15 2023, 03:59 PM
Senior Member Group: Members Posts: 781 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
so we put the original 62k engine back in that had not had the distributor removed. Adjusted the valves (again after we put about 10 miles on it) we rebuilt the Webbers and it fired up. We did some timing and tweaking on the carbs.
It ran OK but a little shy of perfect. I replaced the wires and it seemed to improve it but idled a little high around 1,200. My son came over to work on it the next day, but I wasn't home. All of a sudden, it won't even run. we swapped distributers (both 009's) with the parts car, then swapped points (adjusted to 0.016). no improvement. tested spark to all four cylinders. I seems like it's really out of timing but we didn't change it much. (except for the fact that we took the distributor out) my son says we have spark, too much fuel, and not enough air. What do we do next????? |
Superhawk996 |
Mar 15 2023, 10:22 PM
914 Guru Group: Members Posts: 5,780 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
What is the static timing set at? Should be about 5-7 degrees BTDC. Have you confirmed this?
Dustin914 |
Mar 20 2023, 04:54 PM
Newbie Group: Members Posts: 3 Joined: 3-January 23 From: St. Louis, MO Member No.: 27,076 Region Association: None |
Lo-Fi Version | Time is now: 8th May 2024 - 11:26 AM |
