What went wrong?, it was running great and then not at all |
Type 47 |
Mar 15 2023, 03:59 PM
Senior Member Group: Members Posts: 780 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
so we put the original 62k engine back in that had not had the distributor removed. Adjusted the valves (again after we put about 10 miles on it) we rebuilt the Webbers and it fired up. We did some timing and tweaking on the carbs.
It ran OK but a little shy of perfect. I replaced the wires and it seemed to improve it but idled a little high around 1,200. My son came over to work on it the next day, but I wasn't home. All of a sudden, it won't even run. we swapped distributers (both 009's) with the parts car, then swapped points (adjusted to 0.016). no improvement. tested spark to all four cylinders. I seems like it's really out of timing but we didn't change it much. (except for the fact that we took the distributor out) my son says we have spark, too much fuel, and not enough air. What do we do next????? |
technicalninja |
Mar 21 2023, 10:39 AM
Senior Member Group: Members Posts: 1,156 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Yep, I'm sorry I may have added to the confusion.
I'll never retract something I post in error. I'll allow my lack of knowledge to be in full view of all. I will apologize and re-post if I'm wrong, however. You should notice that I was damn close to what the timing should be at that RPM. I posted 25+degrees at 3500 rpm. I was 2 degrees off! I just pulled that number out of my knowledge base in my memory. Red mark is 27 and 0 mark is TDC. How did Porsche expect technicians to be able to set timing to 7.5 advance at 850 rpm as my timing sticker states? I wasn't aware of any timing lights that could do advance back then... I started doing this stuff professionally (all this means is being paid) in 1982. |
Lo-Fi Version | Time is now: 28th April 2024 - 01:43 AM |
