Type 47 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 791 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None ![]() ![]() |
so we put the original 62k engine back in that had not had the distributor removed. Adjusted the valves (again after we put about 10 miles on it) we rebuilt the Webbers and it fired up. We did some timing and tweaking on the carbs.
It ran OK but a little shy of perfect. I replaced the wires and it seemed to improve it but idled a little high around 1,200. My son came over to work on it the next day, but I wasn't home. All of a sudden, it won't even run. we swapped distributers (both 009's) with the parts car, then swapped points (adjusted to 0.016). no improvement. tested spark to all four cylinders. I seems like it's really out of timing but we didn't change it much. (except for the fact that we took the distributor out) my son says we have spark, too much fuel, and not enough air. What do we do next????? ![]() |
cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 678 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
Hi,
You never said what fixed your no start problem. Something did. Care to share? Carb setup - I have limited Webber experience. I prefer Dellortto. In either case I never open more than one air bypass screw per side. I generally follow this procedure aircooled.net Carb sync |
Type 47 |
Hi, You never said what fixed your no start problem. Something did. Care to share? Carb setup - I have limited Webber experience. I prefer Dellortto. In either case I never open more than one air bypass screw per side. I generally follow this procedure aircooled.net Carb sync Carlos, while we did get the engine fired it's far from fixed. I will be reading your carb instructions next, thanks for posting the link. |
Lo-Fi Version | Time is now: 18th July 2025 - 07:01 PM |
