T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,045 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
Superhawk996 |
Mar 17 2023, 11:06 AM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I was thinking about this a little more.
What might be interesting is to have the “tin” made of aluminum. Aluminum conducts heat better than steel. Why not use that to help draw heat out of the case and the heads a little more quickly. Making use of the enhanced conduction to get the heat into the aluminum shroud. Then it can be carried away by the forced convection provided by the fan. Taking this a step further, could some fins be placed in strategic areas inside the tin to add even more surface area to the shroud so that the convection is more efficient? Fins would have to be parallel with the air flow to minimize flow restriction. (IMG:style_emoticons/default/idea.gif) Copper is even more thermally conductive than aluminum. Pricy but amazing at thermal conduction Would sort of look cool all polished up on outside. Might be time to think of extending the copper metal shaping to a set of 914 “tin”. I think I should at least finish the Norton before I get that distracted. (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 07:04 PM |
