T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,045 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
technicalninja |
Mar 17 2023, 01:40 PM
Senior Member Group: Members Posts: 1,190 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
Insulating the tin should mean less heating of the air in the upper engine compartment.
Less heating of the carbs/FI everything on top. It also might help seal leaks if you did it right. It should actually increase temps underneath the tin. Getting rid of the oil cooler (remote cooler install) and eliminating both of the flaps are in the cards for my car (down here in hell) but this might not be a good idea in the cooler climates. I think the biggest heat capacity gains is ensuring the coolest air at the highest pressure enter the fan housing. I believe (and I might be wrong) the reduction in temp ABOVE the tin is where the gains are with this idea. Designing/bending/modifying the existent tin to force more air through the fins on the heads and jugs will also be looked at. Figuring out how to direct airflow (without increasing aerodynamic drag) into the upper compartment will be one of the things I concentrate on. |
Lo-Fi Version | Time is now: 6th May 2024 - 07:24 PM |
