T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,042 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
Nogoodwithusernames |
Mar 28 2023, 02:08 PM
Member Group: Members Posts: 236 Joined: 31-May 16 From: Nor-Cal Member No.: 20,051 Region Association: None |
Might be a bit OT, but I've seen things on TheSamba before that a couple of holes up in the corner of the top tin over #3 can help relieve turbulence caused by high static pressure and will increase cooling at higher RPMs.
Jake Baby supposedly found it in some of his testing but I haven't found an original reference to that anywhere yet. But Ray Greenwood also accidentally found it and his response to me was as follows. "No I do not remember that he [Jake Baby] posted a diagram or size. But, when I was drilling holes for testing, I was drilling 3/8" holes. I had one in the farthest back corner of the top sheet metal tin for 3/4 right before it turned downward io the crevice. I was trying to check the temp of the head fins there. I drilled one more about 2" further toward the case to try to check the cylinder fins. Between those two 3/8" holes....I was plugging each after I used them.....with duct tape...but it came off on a drive....and I saw about a 50* drop in head temps on #3. I double taped it and repeated the route and the head temps went back up. " It is something I am wanting to test in the near future in my T4 converted VW Squareback and possibly the 914. |
Lo-Fi Version | Time is now: 6th May 2024 - 07:14 AM |
