T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,045 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
emerygt350 |
Mar 28 2023, 03:21 PM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Does an oil cooler do anything for head temps? During normal driving My oil is so cold it concerns me. My head temps are fine and change quickly based on load. It's early in the season of course and my 2.0 is stock besides the exhaust and kn filter.
I would suspect a remote oil cooler in a normal engine would just result in oil that is too cool for far too long. At least in my engine. I am very interested to see what the temps in my car look like under race ish conditions. In autocross I end up at around 220 oil and the heads don't get that hot 310. But that is pretty much redline for 60 seconds in second and third gear. Not exactly normal. P.s. finger lakes region, we have an air force runway so it is a pretty linear and high speed autocross. |
VaccaRabite |
Mar 29 2023, 05:48 AM
En Garde! Group: Admin Posts: 13,440 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Does an oil cooler do anything for head temps? During normal driving My oil is so cold it concerns me. My head temps are fine and change quickly based on load. It's early in the season of course and my 2.0 is stock besides the exhaust and kn filter. Not really. Oil temps and head temps tend to move independently of one another. I tend not to think highly of using oil temps as "the" indicator of engine temp. Like you, I also monitor head temps. Keeping the oil cool is good in that it keeps the oil from premature breakdown - which was more of a problem in the past then it is these days. But head temps is what's going to determine if you are going to loose a valve seat and munch a cylinder. Oil provides some cooling of the heads, but only some. QUOTE I would suspect a remote oil cooler in a normal engine would just result in oil that is too cool for far too long. This is not my experience, but it really depends on how the cooler is set up. In my 2056, the oil cooler is shut until the oil hits about 180 degrees, and then flow is opened to the cooler. At 205 the fans turn on. My oil temps stay around 215 on long drives with a heavily loaded 914. For my new engine I'm going to try the cooler without the fan pack first and see how that does for temps. I'd like to eliminate the electrical draw of the fan pack if possible. Ideally an aux cooler is not always on, but has some sort of thermostat control to allow the engine to warm up. Shoving cold oil through your cooler isn't good for anyone. Zach |
Lo-Fi Version | Time is now: 6th May 2024 - 09:33 PM |
