T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,045 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
emerygt350 |
Apr 1 2023, 02:19 PM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
You don't want low oil temperature though. Optimal oil temp is at least 210. Lower than that you can end up with all kinds of impurities and end up weakening the oil and damaging the engine. I see lots of water cooled engines that people put low temp thermostats in which never allow the engine to reach even 180 degrees. Not a good plan.
Superhawk996 |
Apr 1 2023, 04:46 PM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
You don't want low oil temperature though. Optimal oil temp is at least 210. Lower than that you can end up with all kinds of impurities and end up weakening the oil and damaging the engine. I see lots of water cooled engines that people put low temp thermostats in which never allow the engine to reach even 180 degrees. Not a good plan. Sacrilege - just look at all the folks shooting for 190F oil or getting completely freaky when oil hits 230F (IMG:style_emoticons/default/wacko.gif) But. . . Interwebz mythology won’t die (IMG:style_emoticons/default/dead horse.gif) (IMG:style_emoticons/default/hide.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 09:39 PM |
