T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,045 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
r_towle |
Mar 31 2023, 09:20 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
These are oil cooled engines using air.
Complete and proper tin, with every piece sealed properly along with sealing off all air passages from top to bottom , that seems to be all we need except really hot areas of the world, or when you raise the HP up over 150 ish |
wonkipop |
Apr 1 2023, 04:56 PM
Advanced Member Group: Members Posts: 4,264 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
These are oil cooled engines using air. Complete and proper tin, with every piece sealed properly along with sealing off all air passages from top to bottom , that seems to be all we need except really hot areas of the world, or when you raise the HP up over 150 ish even works in real hot areas of world. beetles were legendary in outback australia. back when water cooled cars regularly overheated. beetles just kept going no problem. the only ones that suffered a bit were the type 3 with the suitcase motor. you had to back off in summer out on the open road. hold them at 55 mph cruise. then they were happy. the horizontal oil cooler laid over cylinder 3 was a flaw. the type 4 probably has the best designed cooling system of them all. perhaps in a hi po version with increased capacity it gets dicey, but not in stock form. they sorted out the oil cooler location and ducting. interesting conversation here, but for my two bobs worth i think engine tin material is kind of a marginal gain if anything. a bigger fan and more air flow is probably the answer. ducting to the fan? the type 4 sedan and wagons all had a dedicated sealed boot and duct to the cooling fan and could draw the air in from optimal surfaces on the external body work. |
Lo-Fi Version | Time is now: 6th May 2024 - 04:01 PM |
