T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,045 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
914werke |
Apr 1 2023, 07:13 PM
I found that it takes a lot of detailing to properly seal off the top of the engine. (IMG:style_emoticons/default/agree.gif) Remember Some of what were talking about here was already present from the factory. For instance the front tin sections creating the well for the fan & alternator had/has weatherstripping like material to seal up those pieces. why that wasn't applied to all the tin ..... (IMG:style_emoticons/default/confused24.gif) |
r_towle |
Apr 1 2023, 08:51 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I found that it takes a lot of detailing to properly seal off the top of the engine. (IMG:style_emoticons/default/agree.gif) Remember Some of what were talking about here was already present from the factory. For instance the front tin sections creating the well for the fan & alternator had/has weatherstripping like material to seal up those pieces. why that wasn't applied to all the tin ..... (IMG:style_emoticons/default/confused24.gif) Kind of my point. Now, we have all removed , refinished, and reinstalled all the tin Those gaskets were put there to prevent the fan from sucking in hot air from below. There were other gaskets around the oil cooler too. Rich |
Lo-Fi Version | Time is now: 6th May 2024 - 07:23 PM |
