T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,042 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
moto914 |
Apr 2 2023, 04:51 PM
Newbie Group: Members Posts: 36 Joined: 27-February 17 From: Greenville SC Member No.: 20,878 Region Association: South East States |
Hi. My around town & ocasional 2 hr highway runs, avoiding traffic jams (getting a snack at an exit) head temps were ok.
The interest here is in the discussion. "Upgrade the Floor Pan Air Deflectors" Nice point. " Front ducting to eng. fan" Stated to work. So how about some sort of scoop routing air through floor pan deflectors, for those who performance drive. Any thoughts? |
r_towle |
Apr 2 2023, 06:04 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Hi. My around town & ocasional 2 hr highway runs, avoiding traffic jams (getting a snack at an exit) head temps were ok. The interest here is in the discussion. "Upgrade the Floor Pan Air Deflectors" Nice point. " Front ducting to eng. fan" Stated to work. So how about some sort of scoop routing air through floor pan deflectors, for those who performance drive. Any thoughts? The firewall air deflectors create more “suction” under the car to help the fan blow air down. |
914sgofast2 |
Apr 2 2023, 06:13 PM
Senior Member Group: Members Posts: 614 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Hi. My around town & ocasional 2 hr highway runs, avoiding traffic jams (getting a snack at an exit) head temps were ok. The interest here is in the discussion. "Upgrade the Floor Pan Air Deflectors" Nice point. " Front ducting to eng. fan" Stated to work. So how about some sort of scoop routing air through floor pan deflectors, for those who performance drive. Any thoughts? The firewall air deflectors create more “suction” under the car to help the fan blow air down. Anyone know why the factory used two (2) under the car firewall deflectors instead of one longer piece across the bottom of the car at the bottom of the firewall? When factories stared putting air deflectors/air dams under the front of cars to force more air into the radiator in front engined, water cooled cars, they used a long continuous piece of rubber/plastic below the bumper/radiator opening. |
Lo-Fi Version | Time is now: 6th May 2024 - 08:43 AM |
