T4 Engine tin: thermal design |
914werke |
Mar 16 2023, 05:25 PM
"I got blisters on me fingers" Group: Members Posts: 10,042 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
So seeing a product recently got me thinking about the result of its application & my own observations of how well (or not) the T4 handles air flow, Engine block cooling & resulting oil temperatures. (IMG:style_emoticons/default/smile.gif)
Its somewhat well known that ...in the 914.. the T4 suffers from less than optimal cooling from the front mounted impeller/fan particularly to the #3 Cylinder & that it is vitally important to seal the tins multiple openings to contain as much laminar air flow front to back over the finned cylinders. In a gross approach, the goal was to seal the engine compartment "intake" air on top from the eng. heated "cooling" air below the tins. When a motor is new and all its components serviced & refreshed, the design does, or did, a pretty good job. After years of use (neglect), elements (oil dirt mice ext) conspire to restrict that air flow. As well as eng. heat causing hardening of rubber pieces that are intended to help contain that cooling air below. Now almost 50 yrs on I see fewer & fewer "STOCK" engine configurations which you can guess usually means more heat to deal with. Jake addressed the cooling air via his(?) DTM solution, but IMO its not very practical for stock or near stock motors (& expensive) The go-to response to eliminate that heat is usually an additional or a remote oil cooler which comes with its own set of challenges. (IMG:style_emoticons/default/confused24.gif) How about KISS (IMG:style_emoticons/default/biggrin.gif) Has anyone used any of the Fiberglass based stick-on reflective heat shielding products on the engine-sides of the tin? Idea being rather than allow heat absorption to all the those steel pieces reflect it back to carried away by the cooling air? BTW Im not a Porsche engineer...but I did stay in a Holiday Inn last night (IMG:style_emoticons/default/happy11.gif) |
Mikey914 |
Apr 5 2023, 10:53 AM
The rubber man Group: Members Posts: 12,656 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The 2 deflector design works very well. You have 4 vortices aligned with the cylinder areas that are creating a low-pressure area immediately behind them. The are not a scoop in a traditional sense. The do cause the air in the engine compartment to be pulled down and carried off. Increasing the efficiency of cooling. Think of the fan pushing air, and the low-pressure area sucking it.
This is one of the reasons we added "winglets" to the design. Keeping the air from rolling immediately over the edge and helping to increase the low pressure. It a 3% increase in efficiency. Not much, but if we are going to create something why just copy it?? Attached image(s) |
914_teener |
Apr 5 2023, 12:57 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
The 2 deflector design works very well. You have 4 vortices aligned with the cylinder areas that are creating a low-pressure area immediately behind them. The are not a scoop in a traditional sense. The do cause the air in the engine compartment to be pulled down and carried off. Increasing the efficiency of cooling. Think of the fan pushing air, and the low-pressure area sucking it. This is one of the reasons we added "winglets" to the design. Keeping the air from rolling immediately over the edge and helping to increase the low pressure. It a 3% increase in efficiency. Not much, but if we are going to create something why just copy it?? Come on Mark...ya just looked over the port side of your airship on the end of the wing and thought it was a good idea! (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 6th May 2024 - 05:53 AM |
