914 Battery, Odyssey models, other AGM brands? |
JamesJ |
Mar 17 2023, 12:24 PM
Member Group: Members Posts: 220 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hello World,
I am needing a new battery for my 2.2 four cylinder 914. I have read many of the battery threads from recent years. I know many of you have had success with Optima, but I've also read about the quality concerns in recent years. The Odyssey seems like a good choice as I've not read any threads addressing quality concerns with this brand. The Odyssey Group 42 standard size battery for our 914s is 600 CCA, is as heavy as a lead acid battery at about 40 lbs., but it is a plug and play(no extra bracket required). I am not opposed to this option, but like the idea of a much lighter battery. Odyssey sells a PC925(330 CCA at 24 lbs.) and a PC680(170 CCA at 15 lbs). My mechanic friend recommended that I stay within 100 CCA of the standard size Group 42 battery, which would mean at least 500 CCA. My car is stored at a remote storage facility that does not have power, so a battery charger/tender is not an option for me. I currently disconnect the negative battery cable when not using the car, but will purchase a disconnect switch when I purchase the new battery. The car is not a daily driver, and it's not unusual for the car to sit for a week or two at a time without starting or driving it. I have a/c and a CLA for my cell phone, but no radio or other electronic gadgets and I don't run any of the above with the key on. I've read where several of you have the PC680 or PC925 and have not had any starting issues, but I don't know how often you start your cars or if you use a battery charger/tender to keep it from draining down. I live in California, so CCAs are not as critical as other areas in the country. Any thoughts on CCA ratings or other issues I should consider? For terminals, do you use the SAE battery posts or the M6 receptacles? Other AGM brands recommended? Thanks! |
VaccaRabite |
Nov 15 2023, 06:31 AM
En Garde! Group: Admin Posts: 13,442 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I had a PC925 in my car.
I went back to a standard battery. The PC925 just cant store enough energy if the alternator doe not perform at its peak for some reason at night. I got left stranded on a 20 minute drive when the alternator was not charging at full power. The PC925 was at full charge when I left the house. it lasted 15 minutes and died. Standard or Gel batteries are heavier, yes. But most of the can sustain a car for 30 - 40 minutes in the event of a charging issue to get you home or to somewhere safe. I would NOT put Lithium batteries in my car without special chargers built for them specifically. Also, I'd look for LiFePo4 batteries instead of L-Ion batteries. Zach |
Spoke |
Nov 26 2023, 08:51 AM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I had a PC925 in my car. I went back to a standard battery. The PC925 just cant store enough energy if the alternator doe not perform at its peak for some reason at night. I got left stranded on a 20 minute drive when the alternator was not charging at full power. The PC925 was at full charge when I left the house. it lasted 15 minutes and died. Standard or Gel batteries are heavier, yes. But most of the can sustain a car for 30 - 40 minutes in the event of a charging issue to get you home or to somewhere safe. I would NOT put Lithium batteries in my car without special chargers built for them specifically. Also, I'd look for LiFePo4 batteries instead of L-Ion batteries. Zach @VaccaRabite Zach, what battery did you end up buying? Was it AGM? I need to replace my Optima red top. After 20 years the first start up of the day is very slow. |
VaccaRabite |
Nov 27 2023, 10:07 AM
I had a PC925 in my car. I went back to a standard battery. The PC925 just cant store enough energy if the alternator doe not perform at its peak for some reason at night. I got left stranded on a 20 minute drive when the alternator was not charging at full power. The PC925 was at full charge when I left the house. it lasted 15 minutes and died. Standard or Gel batteries are heavier, yes. But most of the can sustain a car for 30 - 40 minutes in the event of a charging issue to get you home or to somewhere safe. I would NOT put Lithium batteries in my car without special chargers built for them specifically. Also, I'd look for LiFePo4 batteries instead of L-Ion batteries. Zach @VaccaRabite Zach, what battery did you end up buying? Was it AGM? I need to replace my Optima red top. After 20 years the first start up of the day is very slow. I went backwards. Standard lead acid AC Delco. I’ve not bought a Red Top in about a decade. I’m sure that they have fixed thier issues from 10 years ago. But modern batteries don’t really leak anymore, so I don’t see the point in spending the extra money. Zach |
Spoke |
Nov 27 2023, 08:13 PM
I had a PC925 in my car. I went back to a standard battery. The PC925 just cant store enough energy if the alternator doe not perform at its peak for some reason at night. I got left stranded on a 20 minute drive when the alternator was not charging at full power. The PC925 was at full charge when I left the house. it lasted 15 minutes and died. Standard or Gel batteries are heavier, yes. But most of the can sustain a car for 30 - 40 minutes in the event of a charging issue to get you home or to somewhere safe. I would NOT put Lithium batteries in my car without special chargers built for them specifically. Also, I'd look for LiFePo4 batteries instead of L-Ion batteries. Zach @VaccaRabite Zach, what battery did you end up buying? Was it AGM? I need to replace my Optima red top. After 20 years the first start up of the day is very slow. I went backwards. Standard lead acid AC Delco. I’ve not bought a Red Top in about a decade. I’m sure that they have fixed thier issues from 10 years ago. But modern batteries don’t really leak anymore, so I don’t see the point in spending the extra money. Zach Thanks. Stopped at Autozone and picked up an AGM battery. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 12th May 2024 - 06:43 PM |
