914 Battery, Odyssey models, other AGM brands? |
JamesJ |
Mar 17 2023, 12:24 PM
Member Group: Members Posts: 220 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
Hello World,
I am needing a new battery for my 2.2 four cylinder 914. I have read many of the battery threads from recent years. I know many of you have had success with Optima, but I've also read about the quality concerns in recent years. The Odyssey seems like a good choice as I've not read any threads addressing quality concerns with this brand. The Odyssey Group 42 standard size battery for our 914s is 600 CCA, is as heavy as a lead acid battery at about 40 lbs., but it is a plug and play(no extra bracket required). I am not opposed to this option, but like the idea of a much lighter battery. Odyssey sells a PC925(330 CCA at 24 lbs.) and a PC680(170 CCA at 15 lbs). My mechanic friend recommended that I stay within 100 CCA of the standard size Group 42 battery, which would mean at least 500 CCA. My car is stored at a remote storage facility that does not have power, so a battery charger/tender is not an option for me. I currently disconnect the negative battery cable when not using the car, but will purchase a disconnect switch when I purchase the new battery. The car is not a daily driver, and it's not unusual for the car to sit for a week or two at a time without starting or driving it. I have a/c and a CLA for my cell phone, but no radio or other electronic gadgets and I don't run any of the above with the key on. I've read where several of you have the PC680 or PC925 and have not had any starting issues, but I don't know how often you start your cars or if you use a battery charger/tender to keep it from draining down. I live in California, so CCAs are not as critical as other areas in the country. Any thoughts on CCA ratings or other issues I should consider? For terminals, do you use the SAE battery posts or the M6 receptacles? Other AGM brands recommended? Thanks! |
technicalninja |
Mar 19 2023, 09:23 AM
Senior Member Group: Members Posts: 1,156 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
The Li-ion batteries scare me enough to not run them in anything but a track car.
My youngest, Michael, was a track marshal for MSR (Motor Sport Ranch). If any of you have video where a young blond "punk" made funny faces in your camera just before you left the pit area, that's my son... One of his duties was fire suppression. A Li-ion battery fire is very similar to a magnesium fire. Nothing but burying them puts them out. 20 minutes AFTER you think you have it out it starts back up. A lithium-ion battery fire almost always takes the entire car with it. These are NOT cheap batteries either. A 200K track car usually gets the very best equipment. Owners are pissed when this happens... They have lost multiple cars and garages to Li-ion battery fires at MSR. I do see the benefits to the Li-ion batteries but until these becomes less flammable, I'll stay with heavier batteries. I wish my Optimas lived as long as Clay's and Jim's... 10 years is a shitload for any battery. Had mine lived longer I'd recommend them over everything else. Optimas can fail but when they do they just barf their guts out of the cases. I have not heard of any fires being associated with this. The usual reason for Optima failure is long term trickle charging with equipment that is not specific for Optima batteries. The Optima smart chargers are a bit on the expensive side and don't work seamlessly with lead acid batteries. Out at MSR, Porsches gained the title "fire lizards" due to the fact when they leave the track and slither into the grass they catch it on fire far more often than any other brand of car... PCA and Porsche events at MSR were always super professional with extremely friendly people. Michael loved to work when the fire lizards were running. The motorcycle crowds were exactly the opposite... |
914rrr |
Nov 29 2023, 08:43 AM
Senior Member Group: Members Posts: 1,821 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
The Li-ion batteries scare me enough to not run them in anything but a track car. My youngest, Michael, was a track marshal for MSR (Motor Sport Ranch). If any of you have video where a young blond "punk" made funny faces in your camera just before you left the pit area, that's my son... One of his duties was fire suppression. A Li-ion battery fire is very similar to a magnesium fire. Nothing but burying them puts them out. 20 minutes AFTER you think you have it out it starts back up. A lithium-ion battery fire almost always takes the entire car with it. These are NOT cheap batteries either. A 200K track car usually gets the very best equipment. Owners are pissed when this happens... They have lost multiple cars and garages to Li-ion battery fires at MSR. I do see the benefits to the Li-ion batteries but until these becomes less flammable, I'll stay with heavier batteries. I wish my Optimas lived as long as Clay's and Jim's... 10 years is a shitload for any battery. Had mine lived longer I'd recommend them over everything else. Optimas can fail but when they do they just barf their guts out of the cases. I have not heard of any fires being associated with this. The usual reason for Optima failure is long term trickle charging with equipment that is not specific for Optima batteries. The Optima smart chargers are a bit on the expensive side and don't work seamlessly with lead acid batteries. Out at MSR, Porsches gained the title "fire lizards" due to the fact when they leave the track and slither into the grass they catch it on fire far more often than any other brand of car... PCA and Porsche events at MSR were always super professional with extremely friendly people. Michael loved to work when the fire lizards were running. The motorcycle crowds were exactly the opposite... I worked, very breifly, for a LI battery "manufacturer" in Clearwater, FL. 98% of their batteries are made in China and they merely slap a "Made in USA" label on it. Most LI battery sites claim plug n' play / direct swap compatability for lead acid batteries. DO NOT BELIEVE THEM! I quit over their objections to my suggestions of CYA language to add to their website, woefully inadequate fire safelty / supression in their building (they didn't even have a sprinkler system!), "made up" date codes on batteries, numerous "off the books" settlements for battery fires / explosions (one boat battery took out a $MM garage and house), etc etc.. DO YOUR HOMEWORK before choosing a LI battery for anything other than a track car. LI batteries run at different voltages, require LI specific chargers, don't like cold or really hot weather, thermal runaway safety concerns, etc, etc. Read articles below for more info: https://www.ien.com/safety/news/21136518/fi...r-battery-rules https://www.batteriesplus.com/blog/power/lithium-starting |
Lo-Fi Version | Time is now: 27th April 2024 - 06:31 PM |
