The two bleeders |
The two bleeders |
emerygt350 |
Mar 17 2023, 07:38 PM
Advanced Member Group: Members Posts: 2,087 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I just popped on my newly remastered rear brake calipers from PMB and was wondering if there was a point to the lower bleeder? I only ever bothered with the top bleeder before but now that it's bone dry I was wondering if that might be why the second bleeder exists? I will be bleeding the brakes tomorrow morning.
Superhawk996 |
Mar 19 2023, 12:34 PM
914 Guru Group: Members Posts: 5,779 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Nope - I’m wrong on a casting common to all three applications. You can see the /4 casting has a different formation than the Ferrari rear inboard casting.
The other thing that is implied is that Krieger’s calipers had to be drilled to the /6 orientation meaning that the 308s weren’t dual bleed screw. The mystery continues as to what would prompt ATE to have two bleed screws on the /4. (IMG:style_emoticons/default/confused24.gif) I’m still thinking someone else was using the /4 casting for another OEM. That will take some digging. I’ll see what I can find on ATE classic site. /4 photo from Pelican |
PatMc |
Mar 20 2023, 08:48 AM
Member Group: Members Posts: 119 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
Nope - I’m wrong on a casting common to all three applications. You can see the /4 casting has a different formation than the Ferrari rear inboard casting. The other thing that is implied is that Krieger’s calipers had to be drilled to the /6 orientation meaning that the 308s weren’t dual bleed screw. The mystery continues as to what would prompt ATE to have two bleed screws on the /4. (IMG:style_emoticons/default/confused24.gif) I’m still thinking someone else was using the /4 casting for another OEM. That will take some digging. I’ll see what I can find on ATE classic site. /4 photo from Pelican The ONLY applications that use this type of rear caliper are: 914-4 -914-6 - use a larger version of the 70-72 914-4 piston guts along with the M10 adjuster threads....a unicorn exclusive to the 914-6 caliper Ferrari 308 - uses the same piston guts and M10 adjusters as the Late 914-4 caliper. Alfa (38mm, but different parking brake lever configuration and a few other things)..use the same piston guts as the Ferrari 308, but the external threads on the outer adjuster are M10x1.25 rather than M8x1.25 like the 914 (4 and 6) and Ferrari calipers, and the inner setup is different as well. I've also seen one instance of these being used on a BMW....not sure if OE or not, can't remember the model, but it was something special. The inboard castings are a bit different between the early and late 914-4...the area where you insert the clips to retain the pad pins has a bit more relief on one than the other...maybe just an updated tool, who knows. |
Lo-Fi Version | Time is now: 5th May 2024 - 02:23 PM |
