need some help with floor plan fix, peeling the coating, POR15, etc |
914 RZ-1 |
Mar 17 2023, 08:39 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
The M/C leaked all over the floor plan. There's some rust as well. Before I put back everything I thought I would clean it all up.
1. What is the best way to get all the coating off the floor pan? It looks like some sort of asphalt/tar paper. It seems to be peeling off okay with a putty knife. I'm guessing I use some sort of solvent to get the remaining gunk off? Heat gun? 2. I have a kit that has cleaner/degreaser, metal prep and POR15. I also want to reseal around whatever that is (plug?) in the middle with some seam sealer. What order is this all applied? -cleaner -prep -POR15 -seam sealer OR -cleaner -prep -seam sealer -POR15 Or some other order? 3. I was going to leave the POR15 as the final coat, but do I need to paint over it? The car is silver/gray, the POR15 is gloss black. It's under the carpet and under the floor mat, so it will not show. I'm more concerned with keeping the rust at bay. 4. Where should I stop the painting? At a seal? At one of the changes in contour of the floor pan? Please note that the car was in an accident many years ago (before my ownership) and was repaired, but the floor pan is still a little uneven. My concern is that the paint will wick under the tar paper, but is that even an issue? Here's a photo, since I know we all like pictures. There is a pile of tar paper on the left: Thanks! -Jeff ------------ |
rjames |
Mar 19 2023, 04:11 PM
I'm made of metal Group: Members Posts: 3,939 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
POR15 gets a bad rap. I suppose YMMV could vary, but if you follow their directions, it should work. I’ve only had great experiences with it, but I also followed their directions to the letter.
I painted my floor pans with it 16 years ago after stripping the tar off and removing all surface rust, and then treating as directed with metal ready before applying. The pan looks exactly the same now as they did when the self-leveling paint dried. |
Lo-Fi Version | Time is now: 24th May 2024 - 03:42 AM |
