Can someone post a pic of their distributor in the engine bay, preferably an 009 with Webbers |
Type 47 |
Mar 20 2023, 02:59 PM
Senior Member Group: Members Posts: 780 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
I would like to see the positioning of a properly installed & tuned one.
mikey63 |
Mar 20 2023, 03:16 PM
Member Group: Members Posts: 121 Joined: 30-March 10 From: Windsor,Ca Member No.: 11,529 Region Association: Northern California |
Here is what mine looks like...73 2.0
Attached thumbnail(s) Attached image(s) |
ndfrigi |
Mar 20 2023, 03:29 PM
I think stock TDC is between 10 and 11 o’clock
Type 47 |
Mar 20 2023, 04:05 PM
brubou |
Mar 20 2023, 04:36 PM
Bruce Bouchard Group: Members Posts: 92 Joined: 29-February 16 From: West Bradford, PA Member No.: 19,716 Region Association: MidAtlantic Region |
NARP74 |
Mar 20 2023, 04:47 PM
Senior Member Group: Members Posts: 1,050 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I am still getting upload errors, sorry.
The total file space required to upload all the attached files is greater than your per post or global limit. Please reduce the number of attachments or the size of the attachments. |
Dustin914 |
Mar 20 2023, 04:50 PM
Newbie Group: Members Posts: 3 Joined: 3-January 23 From: St. Louis, MO Member No.: 27,076 Region Association: None |
Dustin914 |
Mar 20 2023, 04:51 PM
Garland |
Mar 20 2023, 05:27 PM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
nditiz1 |
Mar 20 2023, 05:32 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
This also may help. Looking a bit deeper This is the key shot as the gear can be 30 different positions and still be correct. If your gear does not look like it is above then do not rely on the position of the distro to be the same as factory, you need to compensate. |
914werke |
Mar 20 2023, 08:13 PM
"I got blisters on me fingers" Group: Members Posts: 10,004 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Not with an 009 ~
They are clocked either 45 or 90 from OE IIRC. |
Type 47 |
Mar 20 2023, 09:29 PM
Lo-Fi Version | Time is now: 26th April 2024 - 07:30 AM |
