The total file space required to upload all the attached files is greater than your per post or global limit. Please reduce the number of attachments or the size of the attachments.
This is the key shot as the gear can be 30 different positions and still be correct. If your gear does not look like it is above then do not rely on the position of the distro to be the same as factory, you need to compensate.
914werke
Mar 20 2023, 08:13 PM
Not with an 009 ~ They are clocked either 45 or 90 from OE IIRC.
Type 47
Mar 20 2023, 09:29 PM
QUOTE(914werke @ Mar 20 2023, 06:13 PM)
I have an 009
