Dimensions for front triangle, Forward triangle |
Flyinlow |
Mar 20 2023, 06:48 PM
Flyinlow Group: Members Posts: 36 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada |
Hi , was hoping someone could give me a picture and possibly dimensions for the front triangles inside front fenders at front of rockers, mine super bastardized by P.O. Thanks Dennis
friethmiller |
Mar 28 2023, 10:11 AM
Member Group: Members Posts: 475 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I just went out to my car and grabbed the part for you. Here's a pic of what I have left of it (IMG:style_emoticons/default/sad.gif) . Yes, this car has A/C, so ignore the hole(s). The second pic is my "back of the napkin" sketch with some rough'd in dimensions I took directly from the part. I'm not much of a draftsman! The third shows the inside bend and how the outer edge width increases as it moves up the part. I've fabricated these in the past without too much difficulty. I mainly used a vise, if I remember correctly. Your mileage may vary but this should get you close. Good luck!
Flyinlow |
Mar 29 2023, 07:48 AM
I just went out to my car and grabbed the part for you. Here's a pic of what I have left of it (IMG:style_emoticons/default/sad.gif) . Yes, this car has A/C, so ignore the hole(s). The second pic is my "back of the napkin" sketch with some rough'd in dimensions I took directly from the part. I'm not much of a draftsman! The third shows the inside bend and how the outer edge width increases as it moves up the part. I've fabricated these in the past without too much difficulty. I mainly used a vise, if I remember correctly. Your mileage may vary but this should get you close. Good luck! This will help… thanks so much |
Lo-Fi Version | Time is now: 16th May 2024 - 04:04 PM |
