Ninja tips: AC systems |
technicalninja |
Mar 24 2023, 07:32 AM
Senior Member Group: Members Posts: 1,227 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
This thread is my base AC thread for suggestions, questions, whatever...
I run https://granburyautoac.com/ I specialize in automotive heat and air conditioning systems. I've been doing AC work since 1983 and have seen all of the changes, good and bad, that have occurred over the last 40 years. I'm keeping the first post short as they always show up at the top of each page and if long, they clutter up the thread... |
914_teener |
Mar 24 2023, 10:38 AM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
All good advice.
Not enough though about pulling vaccum and evacuating. Anytime you open a system you will introduce moisture which is the death off any AC system. It should be evacuated to the specs negative vaccum and then refilled with clean refrigerant as the poster says with the correct amount of oil for the system. You can rent gauge sets at your local FLAPS. |
Lo-Fi Version | Time is now: 18th May 2024 - 02:07 PM |
