technicalninja
Mar 24 2023, 07:32 AM
This thread is my base AC thread for suggestions, questions, whatever...
I run
https://granburyautoac.com/I specialize in automotive heat and air conditioning systems.
I've been doing AC work since 1983 and have seen all of the changes, good and bad, that have occurred over the last 40 years.
I'm keeping the first post short as they always show up at the top of each page and if long, they clutter up the thread...
technicalninja
Mar 24 2023, 07:45 AM
1st tip and this might be the single most important...
DO NOT purchase any R134a that has anything in it!!
You want the cheap stuff! No AC pro, no easy fill cans, look to the low side of the refrigerant display to find the R134a that is just R134a.
It is perfectly fine to buy this at Walmart. R134a is a chemical and doesn't need fancy labels.
Most of what available at the parts houses has both oil and sealant in it...
The oil doesn't bother me that badly, but the sealant does.
I've never seen it fix a leak, but I've seen too much of it TRASH entire systems.
All of my recycling machines state in the very first sentence of the warranty section
"Any sealants found in the machine void all warranties".
The sealant crap can be the death of your system. Avoid at all costs!!!!
The straight R134a is also the cheapest alternative. Be a cheapskate regarding your refrigerant...
technicalninja
Mar 24 2023, 08:05 AM
2nd stupid important tip.
Change the service valves every single time you evac and charge a system.
The little valves will seal perfectly for 10+ years the very first time they are used.
If they are only 6 months old they might seal a second time. If they are 2 years old or older they will not and all of your refrigerant will leak out slowly over time.
The service valves are the single most common leak on ANY system.
Originally, they were Shrader valves, but they were not normal tire valves. The material that the seals are made out of was higher quality and can seal at much higher pressures than a standard tire valve. If you have a motorhome that has 100psi tires on it the AC valves are the way to go...
There are many styles of valves now. Make sure you're getting the right ones.
Some KIA/Hyundia valves are slightly different than the normal JIS valves and swapping them damages the valve seats. I ran out of the KIA valves once. Both the Kia and Hyundia dealers didn't have the correct valves and didn't knpw they were different!
I re-used the customer's valves and had to re-do the evac and charge 9 months down the road as the 4-year-old original valves didn't seal properly.
I ate the job and didn't charge the customer again. Full blown come back!
I believe I am the only shop in town that would have done that...
These valves are cheap, replace them every time...
Stop the job if you don't have the right parts or you will get additional training!
technicalninja
Mar 24 2023, 08:27 AM
3rd tip...
Oil balancing is very important!
A modern AC system uses approximately 4 ounces of oil per LB of refrigerant.
Putting too much oil in degrades system efficiency. It coats the inside of the tubing and the heat exchangers and can seriously degrade system heat transfer.
The oil DOES NOT stay in the compressor. It runs around the system with the refrigerant and the liquid refrigerant mixes completely with the oil. When the liquid goes through the phase change from liquid to gas it releases the oil as fine droplets and this oil mist is how the compressor oils.
Ever been in front of a fan with a water mister on it?
This is how the compressor oils...
The ONLY thing that needs the oil is the compressor.
Modern compressors have multiple ways they try to keep the oil in the compressors.
IMO none of them work. I expect 33% of the system oil in the compressor and the other 66% will be in the system, mostly in the evaporator as this is the main area the phase change occurs in.
Most of those expensive refrigerant cans have 3 ounces of oil in them. If you've had an explosive decompression of the system, you might lose 3 ounces. Ripping a hose off is an example of explosive decompression. This vents the entire system charge in a second, you get a BIG bang and a pretty impressive cloud for just a moment.
If you haven't violently vented your system, you NEVER need the amount of oil in one of the fancy cans and putting 3 ounces of oil in a system that needed none is "shooting yourself in the foot."
A slow leak does not vent much of the oil out of the system. You might only need a 1/4 ounce of oil. Experience is what makes me able to determine how much oil to put back in. It's usually a very minor amount...
I have a Hybrid capable machine and it did not have an oil injection system.
At first I was pissed, My 5K machine could not inject oil!
I far prefer it that way now.
I use a 60CC cow injection hypodermic srynge to dispense oil into the high side of the system (ONLY!) during vacuum operations. Work like a charm and was dirt cheap.
Robinair and others make an actual oil injector to allow injection of oil into a charges system. I originally wanted one but after getting used to the cow needle I'm fine with out one.
technicalninja
Mar 24 2023, 08:51 AM
I put oil into the system through the high side port only!
Placing it here means it will be absorbed by the liquid and it will reach the compressor as fine droplets.
It is possible to hydro lock a compressor. We call that "slugging" a compressor.
It doesn't do as much damage as hydro locking a ICE engine but it can destroy the reed valves inside the compressor thus rendering a compressor useless.
Now, when I'm doing a full system and I have everything apart, I place 1/3 of the oil in the compressor sump, 1/3 in the entrance to the condenser and 1/3 in the entrance of the evaporator.
Adding oil to an existing system is ONLY done through the high side port when under vacuum.
technicalninja
Mar 24 2023, 09:01 AM
When replacing a compressor, it is stupid important to rotate the compressor by hand at least 20 360-degree revolutions. This clears the cylinders of oil and keeps the compressor from hydro locking from the start.
If a compressor hydro locks, it sounds like a "mouse with a machine gun".
You get a quick "Brrt" and you're done...
Now, a late modern PWM controlled compressor is at full de-stroke when installed and you cannot really clear them. They add stroke slowly and tend to be self-clearing but I am a creature of habit and rotate them anyways.
Some PWM compressors (German stuff mostly) do not have magnetic clutches and cannot be rotated by hand once the belt is on. I rotate those before I place the drive belt.
technicalninja
Mar 24 2023, 09:40 AM
The very first thing I do when checking a system out is feel the aluminum tubing by hand to see if I have any heat transfer going on.
The high side discharge hose from the compressor to the condenser is the very hottest hose in the system. On a 80 degree day it should be warm-hot, on a 100degree day it will be hot, hot like a cloths iron. Be careful here; this line has the ability to burn you.
The liquid line from condenser to expansion device will still be warm but much cooler than the discharge line. Barely warm on a 80 degree day, warm-hot on a 100 degree day but you should be able to hold on to it without burning your hand.
The low side hose from the evaporator to the compressor (suction line) should be cold/cold.
When working properly it will be similar to grabbing on to an ice cube.
This cold starts from the evaporator and extends down to the compressor.
A slightly low system will have this line getting warmer that closer to the compressor it gets.
We want the liquid refrigerant finishing its phase change at the entrance to the compressor.
The phase change absorbs as much as 100 degrees of temperature and a cold line all the way to the compressor is what we are looking for with one exception.
Late modern systems use a secondary cooler where the liquid line post condenser gets wrapped around the suction line to absorb the extra cooling that is available in the suction line. Suction line post secondary cooler is not cold like the entrance suction to the secondary cooler.
This secondary cooler is old school technology. Mercedes used this set up in the late 70s to cool the return fuel to the fuel tank to reduce evapoatory emissions.
What was once used to cool fuel is now used to cool refrigerant.
These secondary coolers are far more common on R1234yf systems but some late R134a systems have them.
@ClayPerrine This is a item I may try to incorporate into a modern 914 system to do what you have done by adding a secondary condenser. I just need to find a secondary cooler that is long and thin to work in the right side rocker panel where the lines go in a stock ac equipped 914.
This is it for my text barfing for today. I've got to go fix a bunch of ac systems and will be busy...
VaccaRabite
Mar 24 2023, 09:50 AM
Ninja are you going to be offering 914 AC?
Zach
914werke
Mar 24 2023, 10:28 AM
914_teener
Mar 24 2023, 10:38 AM
All good advice.
Not enough though about pulling vaccum and evacuating.
Anytime you open a system you will introduce moisture which is the death off any AC system. It should be evacuated to the specs negative vaccum and then refilled with clean refrigerant as the poster says with the correct amount of oil for the system.
You can rent gauge sets at your local FLAPS.
VaccaRabite
Mar 24 2023, 10:42 AM
QUOTE(914werke @ Mar 24 2023, 12:28 PM)
This picture confuses me.
Did someone plumb AC.... into a dune buggy?
Zach
technicalninja
Mar 24 2023, 10:44 AM
I'm not finished, just starting. multiple days of information downloading will happen.
I'm just busy working on customer stuff.
Will have multiple posts regarding evac and charge and the need and time for vacuum.
I suck HARDER and LONGER than anyone else I know!
Overnight is common for me...
914_teener
Mar 24 2023, 10:46 AM
QUOTE(VaccaRabite @ Mar 24 2023, 09:42 AM)
Zach
Nice catch Zach....I saw a Baja in AZ last week.. with AC. It was 46 degrees outside so I quess they didn't need it that day.
Crank fire as well?
technicalninja
Mar 24 2023, 10:47 AM
Not really planning on offering AC systems for anything.
I will, however, train you all to do it yourself with supply vendor info and all you will need to know...
Mar 24 2023, 11:37 AM
QUOTE(technicalninja @ Mar 24 2023, 12:47 PM)
914werke
Mar 24 2023, 12:59 PM
QUOTE(914_teener @ Mar 24 2023, 09:46 AM)
Did someone plumb AC.... into a dune buggy? Zach
Crank fire as well?
Baja Bug not buggy. & no crankfire you can see the dizzy wires peaking out above the compressor.
Front yard mechanic
Mar 24 2023, 02:56 PM
Looks like a nice set up if you could incorporate a crank fire
DRPHIL914
Jul 7 2023, 11:14 AM
QUOTE(technicalninja @ Mar 24 2023, 12:44 PM)
@technicalninja i was looking back over this because i am looking into AC for the 914 its hot here and humid in SC just like Texas, and i am wondering what you think of using the new electric compressors, this is the direction id like to go, AND i would like to not put a hole in the front trunk so what options would i have for a small system and more compact stuff- nost sure what the call it the evaporator coil finned thing was under the floor board of front trunk, so looking for system design suggestions.
Phil
technicalninja
Jul 7 2023, 01:23 PM
I'm running 14-16 hour days right now, 7 days a week. Customers get down right demanding when the temps are above 100...
Units that take the hot high-pressure gas from the compressor and condense it down to a high-pressure cooler liquid are called condensers.
There is no real downside to running excessively sized condensers (or dual) except weight and the requirement of more refrigerant.
Units that allow the high-pressure liquid to evaporate (rapidly) and absorb heat are called evaporators. Once again, bigger is usually better.
Being large on condenser has a larger effect on efficiency than being large on evap.
Both units are technically heat exchangers.
I'm planning on making a fiberglass 916 style front cap that gives me enough room to install a wide thin core in the bumper and NOT use the normal location, but I haven't finalized anything yet.
Clay suggested another condenser trick that I may employ. Running a small condenser inside the engine compartment ala 911 style condenser in series with a front cooler.
This will most likely KICK ASS!.
When using cheap condensers, I commonly have to correct warpage before install (make them flat) and I believe I will be able to bend a new core to the same arc as the front bumper. I haven't tried this yet, but condensers can take a bunch of straightening and not leak.
I do apologize on not finishing out this thread but what I really need to do is a series of you tube vids explaining automotive AC systems and post them on my website.
This is something I'm going to try and get done in my next slow season.
On electric compressors...
The Mitsubishi electronic compressors work extremely well but require the 600 volt battery pack to function. (Toyota Prius/Cadillac hybrid Escalade) This is too heavy and bulky for a 914. The Cadillac unit is actually mounted on the fender well and not built into the engine like the Prius one.
Clay's unit is straight 12 volt and if it works as it's supposed to it may well be the answer for our 914s.
It will require a Billy bad-assed charging system and maybe a bigger battery.
I haven't seen the unit Clay Perrine is going to use but I am very hopeful it will suffice.
One nice thing about the 914 is the tiny passenger compartment. It is half the size of a standard economy car and this makes it a butt-load easier to cool off.
Smaller parts should work well.
I've helped many Fieros turn into refrigerated meat transport vehicles.
They have tiny cabins as well and run R12.
I actually have a "spec' for the final unit in my car.
I want it to freeze my ass off on a 100 degree day, with the top OFF!
I'll be shooting for 33-34 degree vents on high blower...
Steve
Jul 7 2023, 01:34 PM
QUOTE(technicalninja @ Jul 7 2023, 12:23 PM)
I’m running the benling dm18a7 12v compressor. Draws 60amps at the medium setting. More than enough for our little cockpits.
https://benling.coowor.com/shop/product-det...09087VFAMP1.htm
krazykonrad
Jul 7 2023, 02:16 PM
Thanks for all the AC knowledge! I'm fair to middling on mechanicals, but AC systems are a mystery to me.
technicalninja
Jul 7 2023, 03:37 PM
QUOTE(Steve @ Jul 7 2023, 02:34 PM)
https://benling.coowor.com/shop/product-det...09087VFAMP1.htmThat looks cute!
How do I get one without buying a container full?
Seems a bit small but might work fine for a tiny cabin.
Now, I'm guessing the hell that exists here in North Texas between the middle of June to the middle of September might be a tad hotter than California...
I really need to go visit Clay and check his stuff out.
I just haven't had the time...
Full speed on that little puppy is showing 96 amps and the engineering data seems to never quite match what you hit in the field.
96 constant is a bunch of power...
Like I said "Billy Bad-assed charging system and larger battery"
I've wanted to rip a unit (and battery) out of a Escalade to make a "non-engine" dependant system for Pro-Mod cars.
I'd just figure out how to charge the prius battery via plug in and chage the AC battery up a night when the car is not being used. I'd love to know how long the Prius battery will last with just the AC compressor on it
76-914
Jul 7 2023, 06:40 PM
Thx for starting this post. The timing is perfect as I discovered a freon leak on my evaporator and it seems to be at the expansion valve. It worked fine for 6 years until I overcharged it and blew an O-ring out where the high side connects to the evaporator. I replaced that o-ring but it has been a slow leak for 2 years. This last time the recharge lasted 30 minutes or less.
I won't be able to drop the unit for a close up examination for another month so I'm looking forward to your tutorial on proper use of the gauge set and everything else I probably have done incorrectly thus far.
bahnzai
Jul 10 2023, 06:20 AM
QUOTE(Steve @ Jul 7 2023, 03:34 PM)
https://benling.coowor.com/shop/product-det...09087VFAMP1.htm @Steve Hey Steve, any more details on your setup? I looked at the build link in your signature.
From the pictures it looks like you have been running it for about 3 years. Any feedback, things to improve or do differently? Alternator carry the load ok? It all looks pretty clean in the front trunk!
Thanks!
Steve
Jul 10 2023, 07:56 AM
[/quote]
https://benling.coowor.com/shop/product-det...09087VFAMP1.htm[/quote]
Thanks!
[/quote]
Not much more to tell besides what I put in my blog. I bought the parts several years ago and then had health problems (new knee and shoulder). I sold the parts to 914toy and he installed them in his car. He is running the same evaporator under his dash, Benling dm18a7 12v compressor, 175 amp aftermarket alternator and 3 condensers. One in front and one in each rear fender. His works awesome. The compressor comes with a 3 position rotary switch, low, medium and high. We hard wired it to the medium setting. Low is 40amps, medium is 60 amps and high is around 90 amps. When you turn the evaporator on, it automatically turns on the compressor and all the fans on the condensers. If you google Benling DM18A7 there are multiple places that sell it. Now that my shoulder and knee is healed, I will start working on my cars again. My AC setup is only running the one front trunk floor mounted condenser. It blows nice cold air, but then the pressure creeps up and blows the 100 amp circuit breaker. I'm hoping to start working on it again by the end of this month. I need to swap the tranny in my other 914 first.
bahnzai
Jul 10 2023, 01:56 PM
Thanks Steve, that is a great help!
@technicalninja Sorry for the temporary hijack (or maybe tangent discussion...) Thanks for the AC info you are providing. It is particularly useful!!
technicalninja
Jul 10 2023, 04:30 PM
I like hijackers!
Go off on any tangent you like.
Info is info, everything is helpful!
914e
Jul 14 2023, 02:27 PM
QUOTE(Steve @ Jul 10 2023, 06:56 AM)
How do you plumb the three condensers? Is it a tee fitting to the first two?
Steve
Jul 14 2023, 05:17 PM
QUOTE(914e @ Jul 14 2023, 01:27 PM)
I think they are in series?
@914toy
914Toy
Jul 15 2023, 02:18 PM
Yes, in series. - flow is; to front, onto left rear, onto right rear condensor’s.
914e
Jul 15 2023, 04:11 PM
QUOTE(914Toy @ Jul 15 2023, 01:18 PM)
Thanks
technicalninja
Jul 16 2023, 09:15 PM
Strangeness of having both liquid and gas in a sealed system and the use of gauges...
Folks believe that the gauges alone can be used to correctly charge an ac system.
This is FALSE!
I use the gauges to let me know how the system is working. When a sight glass is available the gauges and the sight glass can be used together to determine if the system is low or high.
AC systems have a range of fill where they function properly. Many systems will have a minimum/maximum charge specification. The specification range is conservative. Most systems will work within a 20% range and the specs are usually 5%.
You CANNOT use pressures alone to correct a system that you didn't prep first.
It is VERY common for a car to show up with what look like good pressures (200/30) and have piss poor cooling. After service that same car (which was 60% low on refrigerant) will show 180/24...
WTF!
How do I end up with LOWER pressures after adding .9lb to a 1.6lb system!
It's dirt simple...
I removed excess air from the system.
1% air will screw up the gauge readings, 4% air will make the system not function.
This is assuming you are using R134A. R12 is far more forgiving regarding both air and moisture.
A better indicator of system fill is the temperature of the low side return hose.
When stuff is right it's like grabbing onto an ice cube. It should be stupid cold and wet.
You might even find frost!
I use the temperature of all of the hoses to INSTANTLY tell me what is going on in a system.
The discharge line is the beginning of high side from compressor to condenser and is the hottest in the system. At 70 degrees ambient it should feel like a hot bath.
At 90 ambient it's pretty hot. I wouldn't hang onto it for more than 10 seconds.
At 105 ambient you should treat it like a cloths iron. Just touch for a milli-second. It can burn you pretty good.
Next is still on hot/high side. The liquid line is coming from the condenser to the expansion device. It should be substantially cooler than the discharge line but still above ambient.
70 degrees you can't really feel heat. 90 warm bath, 105 hot bath but not blister creating...
Moving onto low side. This is past the expansion device. This device can be different things at different mounting locations.
What most of us are familiar with is a TXV.
Thermostatic Expansion Valve. This valve's orifice is controlled via the outlet temperature of the refrigerant from the evaporator core; the colder the refrigerant is the smaller the orifice gets. The old school ones had a coiled probe or a capsule that was tightly clipped to the return hose at its exit from the evap core. These were usually covered in "stick-tite" tape. This is a thick tar like insulating tape that you can form together with your hands. These probes have to be well insulated to work properly.
A modern expansion valve is a simple block that has both sides running through. Often the outside of this block is covered with the sticky tape. Insulating these are far less critical and almost all OEM installations no longer uses insulation.
TXV valves are usually directly before (or bolted to) the evaporator core.
Another expansion device is the orifice tube which is a simple restriction made in the liquid line via a plastic insert that has a smaller tube in the center of it.
This can be installed anywhere in the liquid line past the drier assembly.
I think they work best in the entrance of the evaporator, but they can be a good distance from the evap and still function.
Early chevy trucks have them mounted behind the right front turn signal.
2000 up have them mounted in the liquid line about 10 inches away from the firewall/evap entrance.
This is usually where the cold is the very coldest.
We want the suction line from the evaporator to the compressor to be as cold as possible its entire length.
When the gods are in your corner you will see the wet shiny tube suddenly get "flat" looking and frost will appear. At this point the compressor cycles off and the tube turns back to shiny from the compressor end first. It "defrosts" SO FAST that it looks like a "special effects" in a movie. The frost retreats up the tube 6" per second...
As the ac charge weight is dropped the suction tube will gain temperature from the compressor end FIRST!
A little bit low-and the temp difference is small.
A medium bit low (25%) and the tube will be noticeable cooler (10+degrees) near the evap exit (firewall in most cars but not in a 914) versus at the compressor.
Significantly low will feel cooler than ambient but not cold; maybe 60 degrees at evap exit and above ambient at compressor, maybe a bit warm.
Worn out compressor feels much the same.
Compressors, as with so many things, lose the ability to suck FIRST.
I always touch suction first, then liquid, then discharge. Without spending the time to hook up gauges I have a quick assessment of how the system is moving heat.
Cool to ambient suction, ambient liquid, center of hell hot discharge is restricted condenser.
Cool suction, ambient liquid, warm but not hot discharge. Either low on refrigerant or compressor efficiency (gauges will make that determination).
If hoses all feel right, you should have good cooling coming out of the vents. Just after feeling up your hoses, I'm going to hold my grubby hands in front of all your vents.
Ice cold suction and pissy vents (55 degree) you have evaporator housing airflow issues/ blend door/ restricted airflow through evap/bad cabin air filter/blower issues/heater bleed through.
It took far longer to describe this as to do the testing. In 5 seconds I'll have a pretty good "feel" for what your system is doing and where I need to look first...
All temp testing is done at the metal sections of the lines. The rubber portions insulate well enough that they cannot be used.
Enough on system evaluation. Back to some basic physics.
Pressure cannot be used to determine weight. You can take two 30lb jugs of refrigerant in which one of the jugs is full and one is 90% empty. If the jugs are at the same temperature, they will BOTH read what I call "static" pressure. This number can be found on a refrigerant chart. These charts show temperature vs pressure. They are accurate!
If you take the 90% empty jug outside and leave it in the Texas sun in July an hour it will most likely show nearly double the pressure as the full jug that is at 75 degrees.
Your vehicle will show proper static pressure at rest (off the temp charts) if it is 300% overfilled all the way down to not having any liquid at all in the system (95% empty)
The ONLY time it will show more than the charts predict is if it is either hotter than you are estimating or it has a bit of air in it. Air makes the pressures go UP!
The only time your car will show below static is when nothing but vapors exist in the system and you are almost empty.
Everything has an exception.
2011 Camary, Complaint AC goes away after driving for a bit. Car shows up after being driven 20 minutes. 70/0 Vacuum on low side! No temp difference in high/low lines, no cooling. Static pressures should have been 90+ This puppy has less than static on high side and vacuum on low side. Looks empty as shit!
1.1 lb system which I pulled .95lb out of.
Almost completely full!
The expansion valve was too sensitive and was completely closing off sealing the high side from the low side, but it was functional for the first 10 minutes. This allowed the refrigerant to get super cooled by the condenser and just fill it and the liquid line completely up with liquid refrigerant. Way weird!
If the expansion valve did not allow the cooling to happen and was closed on initial start up you might see 450/cut out/450cut out, possible vent refrigerant, damage compressor, a heart attack, system death!
SO, gauges are used to show performance, not weight or charge level.
I have multiple fancy pants recycling machines that have scales that show to the third decimal point. I use these exclusively. I have enough experience and feel that I can get the job done without the machine but I believe the machine is more accurate than I am.
I do want to see what the gauges show after I inject the correct weight of refrigerant.
Only use the cheap 12 oz cans for DIY use. DO NOT use anything with extra oil or especially sealant. I can pretty accurately gauge how much I've let out of a can.
I'm betting you can too...
There are always exceptions to the "rules" Some late model 134 cars and almost all 1234 cars have a secondary cooler which wraps the warm/hot liquid line around and through the ice-cold suction line. This assists cooling of the less efficient new refrigerant but it kills the above novel for a method. It's even more important to use a proper recycling machine with the new crap. It's also slightly explosive so you CANNOT use your old fashion vacuum pump. A new-fangled "sparkless" vacuum pump is a requirement to the new stuff.
They bitched at us for three decades to not use hydrocarbon based refrigerants and now that Dupont/Honeywell says so we all are...
Enough brain dump, should have chopped and channeled this but you're getting it raw.
DO NOT QUOTE THE WHOLE POST PLEASE!
If you have questions, comments, chop and channel appropriately.
More later...
Like I can vary the low side readings in your car by 25 psi by messing with how the system is working. I can vary the high side 100+ using same methods. I can make the gauges read what I want them to without changing the charge level.
Gauges cannot be used to properly fill a system by themselves.
Gauges and basic logic/understanding how the systems work is what's required.
Rick
76-914
Jul 16 2023, 09:51 PM
Rick, I appreciate the time you take to provide us with your real world experience. YouTube is greatly lacking when it comes to AC refrigeration principles and in-depth knowledge. You could probably earn some serious cash if you began a DYI Auto AC clinic on YouTube. Thx again. Kent
