GT steel wheel arches - Dansk or Restoration Design - difference? |
911_2.2T |
Mar 30 2023, 01:38 AM
Newbie Group: Members Posts: 8 Joined: 4-September 12 From: Netherlands Member No.: 14,890 Region Association: Europe |
I'm starting a GT project and need to source a set of steel GT wheel arches.
I've seen that Dansk and Restoration design have them, but is there difference in size, shape and fitting? I've seen some description that Dansk ones can accept up to 9J in width, but I do not want my car to look to wide. Anyone have experience with both vendors parts? |
mepstein |
Mar 30 2023, 04:11 AM
914-6 GT in waiting Group: Members Posts: 19,253 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The Dansk flares are newly released and I haven’t heard of anyone with them on their car so it’s going to be hard to get any real world feedback for another year or so. The restoration Design/auto Atlanta flares have been out for about 15 years so that’s what’s on everyone’s cars right now, except for the few who bought Porsche brand flares.
sixaddict |
Mar 30 2023, 04:28 PM
Senior Member Group: Members Posts: 800 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States |
For what it’s worth, conversion my son now owns has Porsche steel flares. I ran 16 X 9 Fuchs. Ran R-7 Hoosiers (245/45 rear) but had rub. R-6s had no issue.
SirAndy |
Mar 30 2023, 06:43 PM
Resident German Group: Admin Posts: 41,611 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I'm starting a GT project and need to source a set of steel GT wheel arches. I've seen that Dansk and Restoration design have them, but is there difference in size, shape and fitting? I've seen some description that Dansk ones can accept up to 9J in width, but I do not want my car to look to wide. Anyone have experience with both vendors parts? The physical dimensions of all 3 sources should be identical as standard GT flares can accept up to 8J in the front and 9J in the rear without modifications. Of course, you have to have the correct offset on your wheels. You can always run smaller rims with a different offset, nobody forces you to run 9J wheels in the rear. Case in point, i run 7J with 225 tires on all 4 corners using wheel spacers to make sure the wheels fill the wheel arches nicely. As mentioned above, there isn't much feedback on the Dansk flares yet so i can't comment on their fit. The RD/AA flares are good quality but do require some fitting and smoothing. As do the factory flares by the way, they are far from perfect either. (IMG:style_emoticons/default/bye1.gif) |
sixnotfour |
Apr 2 2023, 07:41 PM
914 Wizard Group: Members Posts: 10,418 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
9J ...15s or 16s ?? 15x9s not so much..
911_2.2T |
Apr 4 2023, 01:09 AM
Thanks for the info. The GT flares on my other car must be RRD, they were on it when I bought the car in the US a couple years ago.
Attached thumbnail(s) |
Tom1394racing |
Apr 4 2023, 05:52 AM
Member Group: Members Posts: 276 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States |
mepstein |
Apr 4 2023, 10:31 AM
9J ...15s or 16s ?? 15x9s not so much.. Great chart! Does anyone know the inner wheel well to fender lip dimensions for the RD and AA GT flares front and rear? Don’t take any dimension as gospel. They tend to vary depending on the car and installation. |
sixnotfour |
Apr 4 2023, 07:25 PM
sixnotfour |
Apr 4 2023, 07:27 PM
wheels don t vary , flare lips do..
Yes measure to outside of flare ,lips may vary... |
Tom1394racing |
Apr 5 2023, 08:46 AM
I am planning on Minilites 7X15 front & 8X15 rear with 1" spacers on the front. Tires will be Michelin TB15 18/60R15 front & 23/62R15 rear.
mepstein |
Apr 5 2023, 10:50 AM
I am planning on Minilites 7X15 front & 8X15 rear with 1" spacers on the front. Tires will be Michelin TB15 18/60R15 front & 23/62R15 rear. Should be fine. I have some wood templates that Rory made. It helps you bend the lip into a U shape instead of just trimming it short. I’ll post pics. |
mepstein |
Apr 5 2023, 05:53 PM
Rory's pic and info. I still have to dig up the wood templates.
"The flange is turned up, not trimmed. I traced the curve of the wheel opening and cut a piece of 1/4" plywood to conform to that shape. We then clamped it to the inside of the fender and shaped it (body hammer) as you might find on a standard fender. This adds strength and doesn't take away too much tire clearance. As for the wheel/tires in the rear .... no spacers. I have about 3/4" space on the outside on either side. Add 21mm spacers ? at that point it would be TIGHT. On the inside each has about 1/2" clearance. I don't think 9" wheels will fit. Can I size up from a 225 to a ? 235 , 245 ? on my 8" sixteens ? don't know." Attached image(s) |
sixnotfour |
Apr 5 2023, 07:27 PM
9x15s 245/50 x15s
lip rolled , factory flairs.. one fit one didnt ,, application is everything.. Attached thumbnail(s) |
mepstein |
Apr 6 2023, 06:40 AM
These are the wood templates that Rory used to turn up the inside of the flare. It gives a bit more clearance and keeps the edge of the metal away from the tire. It does change the profile to more of a folded over edge.
Tom1394racing |
Apr 6 2023, 12:16 PM
mlindner |
Jun 25 2023, 05:28 AM
Senior Member Group: Members Posts: 1,515 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
tygaboy |
Jul 2 2023, 05:58 PM
914 Guru Group: Members Posts: 5,279 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
RE: looking too wide, it's down to your wheel width, offset and tire choice.
I wanted wide and went with Ronal 8s and 9s. The 8s are 10.6 offset, just like the 911 Fuchs 8". The 9s are 13 vs the Fuchs 9 at 15. Meaning, in the rear, I'm 2mm wider per side. No spacers, Carrera rotors, Boxster (base, not S) calipers on all 4 corners. My car does look wide, just like I wanted. If this look isn't what you're after, run 7s and 8s, 205/225 and use spacers that give you the look you do want. Just my $0.02. Attached thumbnail(s) |
Lo-Fi Version | Time is now: 2nd May 2024 - 10:03 PM |
