Nevermind |
Nevermind |
BillJ |
Mar 31 2023, 12:46 PM
Senior Member Group: Members Posts: 1,098 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
Not looking now
davep |
Apr 2 2023, 10:56 AM
914 Historian Group: Benefactors Posts: 5,148 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
What you want is another 914/6 box; it has the vent in the correct location and the end cap to mount to the 914.
The internals of the case are generally 901/902/911/914 so spares are in good supply. Some of the very early 901/902 may have a smaller threaded section on the input shaft. You really want to stick to the 911/914 differentials since there were a few incompatible versions with the 914; particularly the aluminum case. There were two 914/6 cases, an early and a late with the late version in greater numbers. The two can be distinguished by the location of the serial: on the rib or off to the side; the latter is more desirable. The 914/6 is set up for the 215 clutch/flywheel. The 225 clutch/flywheel has more capacity, and the pull type actuation is a direct draw on the 914 dispensing with the pulley. |
Lo-Fi Version | Time is now: 24th May 2024 - 03:14 PM |
