123 Distributor Group Buy, Discount to May 6, 2023 |
123ignitionusa |
May 5 2023, 07:45 AM
Member Group: Members Posts: 62 Joined: 22-January 16 From: Ohio Member No.: 19,587 Region Association: North East States |
Hi Richard
My records show you should have the TUNE+ 4-R-V-IE. It may say injection under the product name on the bottom right of the package or to be sure all D-jet distributors have two small wires yellow and white. Those are the trigger wires. Let me know if I mis shipped to you. The D-jet can run a standard carburetted car with out issue, but a non D-Jet will not run an injection car that is running the D-Jetronic injection. As for vacuum all the TUNE+ models come with vacuum as an option. I would recommend if you are going to use it, to use the map curve that comes with the distributor. It adds 10 degrees of vacuum advance on top of the centrifugal curve when the inches of mercury call for it. Many choose to run only the centrifugal curve and that is ok. The map/vacuum curve will only work if a vacuum line is connected to create a signal. It is your choice! Ed - Did I get the right dizzy? Weber's now, D-Jet in fall? What about vacuum? Forgot to ask you about that.. GN aka Richard Hanes Ed, Appreciate your inputs on this Chart. The bottom of the chart is cut off and states: "All but the first two and the last single entry were taken from tables in the factory manual. The others were taken from graphs in the factory manual. The advance curves on the graphs for those first two distributors start at 5 degrees, and increase by 11-15 degrees. Likewise the retard curves start at +5 degrees (advanced) and decrease by 8-10 degrees. However, the last [2.0] graph starts both the advance and retard curves from zero degrees. So a note about "Total advance or retard is relative to the timing with no vacuum" or something to that effect is probably in order." This is where I found it: http://web.archive.org/web/20030202024600/...ww.dgi.net/914/ Would really like your inputs on the programming of my 039 905 205B (which I'm guessing is the last row for the 2.0 noted unlabeled. (It is almost the same as the 205A above it anyway.) Based on the 123 dist instructions, these points need to be doubled (assuming the chart is based on distributor rpm and not crankshaft). Centrifugal: 0 deg @ 900rpm becomes 0 deg @ 1800rpm 9 deg @ 1500rpm becomes 18 deg @ 3000rpm 15 deg @ 2000rpm becomes 30 deg @ 4000rpm 22 deg @ 2800rpm becomes 44 deg @ 5600rpm Vacuum: 0 deg @ 108mmHg becomes 0 deg @ 15kPa and finally 0 deg @ (100-15) 85kPa 7 deg @ 125mmHg becomes 14 deg @ 17kPa and finally 14 deg @ (100-17) 83kPa Does this sound right to you? Would really appreciate your inputs... --- WARNING: Too many @ tags! --- I might be concerned about the all in number of 44 degrees. But only because I know nothing about your cars and what they should be running all in and at how many rpm. So first thing to do is confirm whether the chart is crankshaft or distributor degrees. In my opinion, (which doesn't mean much) normally some timing is needed at start up. In the British car world the starting sweetspot is usually somewhere between 12 and 17 degrees. Your manual should tell you if they are referring to distributor degrees or crankshaft degrees. We always refer to crankcase degrees which are double the distributor degrees. As for the Vacuum I would not use vacuum retard only vacuum advance. Normally the map curve in the app is good and adds 10 degrees when the inches of mercury call for it. You could make that value whatever you like. |
Gatornapper |
May 5 2023, 07:56 AM
Senior Member Group: Members Posts: 1,235 Joined: 22-September 17 From: Woods west of Richmond, VA Member No.: 21,449 Region Association: South East States |
Ed - sent PM.
GN |
NJ914 |
May 5 2023, 10:30 AM
Newbie Group: Members Posts: 37 Joined: 2-November 15 From: Bernardsville, NJ Member No.: 19,324 Region Association: North East States |
Richard: I plan on going through the curves etc this weekend and will get back to you.
Ed: I mistakenly erased the vacuum curve that the 123 distributor came with. Can you please send it to me or post it here...? |
JORACER#40 |
May 5 2023, 03:27 PM
Newbie Group: Members Posts: 11 Joined: 27-October 20 From: San Diego Member No.: 24,815 Region Association: Southern California |
Just purchased
Now the fun begins Ed has been very helpful. Its a nice to have a real person to answer questions and in a timely manner |
123ignitionusa |
May 5 2023, 09:37 PM
If you didn't erase the curve on the distributor by writing the zero curve to it, then it should still be there. Just do a read to find out.
Here is the vacuum curve that comes in all the distributors as a sample. There is also a link HERE. This is a tutorial on curves. Here is an interesting thread - http://www.914world.com/bbs2/index.php?sho...;hl=123ignition |
jcd914 |
May 6 2023, 12:19 PM
Here are some advance curce specs I found that are in "Installed Ignition Distributor", so crankshaft degrees not distributor degrees.
These are all 022 part numbered distributors, I have not found any 039 distributor specs. Jim |
jvmarino |
May 6 2023, 06:47 PM
Member Group: Members Posts: 81 Joined: 22-March 09 From: Baltimore Member No.: 10,188 Region Association: None |
Just installed my BT model. I have a 2.0 with original FI cam and dual Dells. There are only about a hundred different threads on here about setting curves on these distributors, with everyone agreeing to use different values (IMG:style_emoticons/default/wink.gif). I chose a conservative curve to start with and set my car up with a 7 degree static advance. Car started up with no issues and runs fine. Good enough for me at the moment. I was curious why no one seems to just set up the BT unit with 0 degree curve at distributor (set it at TDC) and then just use the programming to dial in the advance from there.
swood |
May 14 2023, 10:41 PM
Senior Member Group: Members Posts: 1,839 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
I’ve been off the board awhile and this distributor is new to me. I misplaced my Mallory unilite vac adv somewhere. Is this a good alternate? Seems like everyone is liking it.
Lo-Fi Version | Time is now: 4th June 2024 - 10:10 PM |
