Comression ratio advice, 6 cylinder motor build |
team914 |
Apr 22 2023, 04:06 PM
Newbie Group: Members Posts: 3 Joined: 5-April 20 From: Ireland Member No.: 24,102 Region Association: Europe |
Hi,
I am planning to build a 6 cylinder street motor for my 914/6 factory replica. My original 84mm barrels were worn, so I elected to machine the barrels to 84.5mm and have bought a set of 84.5mm Wossner pistons. With a 70.4mm crank, the compression ratio is stated at 10.11:1 with the pistons out of the box. I intend on using Weber carbs, E cams and an E distributor/123 Distributor. My machine shop engineer has recommended reducing the compression ratio from the 10.11:1 to a more suitable figure. The petrol quality in Ireland is poor, typically 95 octane, and we now have a compulsory addition of 10% Ethanol added (E10)! Any advice greatly appreciated |
Lo-Fi Version | Time is now: 18th May 2024 - 04:05 AM |
