Fuel Crud, refinish fuel tank |
Bruce Hinds |
Apr 23 2023, 08:19 AM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Can anyone recommend someone in the south sound area that can clean and refinish a fuel tank?
GregAmy |
Apr 23 2023, 08:27 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Cairo94507 |
Apr 23 2023, 08:28 AM
Michael Group: Members Posts: 9,759 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
I agree 100%; buy a new one and never worry about it failing again. (IMG:style_emoticons/default/beerchug.gif)
technicalninja |
Apr 23 2023, 09:26 AM
Senior Member Group: Members Posts: 1,217 Joined: 31-January 23 From: Granbury Texas Member No.: 27,135 Region Association: Southwest Region |
What you need is an old-fashion radiator shop, The type that used to "rod and repair" all of our radiators.
Around here they have all gone out of business as the "new" plastic tanked radiators are uncleanable. Back 20 years ago I commonly paid 100+ to have a tank cleaned. Cannot imagine what they would want now... I'm just going to buy a new tank if mine is the slightest bit messed up. I'm guessing the new tank will be cheaper than having the old one cleaned. |
Superhawk996 |
Apr 23 2023, 10:53 AM
914 Guru Group: Members Posts: 5,821 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
If you only have light surface rust in the tank - phosphoric acid will clean it nicely.
If it’s worse than that, buy a new tank. Stay away from tank sealers. |
Apr 23 2023, 05:09 PM
I agree 100%; buy a new one and never worry about it failing again. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/agree.gif) Just did this. Cheaper than cleaning Much nicer. Replace all gaskets, hoses etc etc |
jhynesrockmtn |
Apr 23 2023, 06:57 PM
Member Group: Members Posts: 418 Joined: 13-June 16 From: spokane wa Member No.: 20,100 Region Association: Pacific Northwest |
I took my 70 tank a few years ago to a radiator place that did a reseal, paint, etc. It looked new but also not stock anymore as they drilled and then plugged a few holes in it. It was more than the new Dansk tanks available now. I am redoing the fuel system on my BB and was surprised the tank was in such bad shape. I just bought a new one.
Bruce Hinds |
Apr 24 2023, 07:18 PM
Thanks all . . .. Got the tank out and after seeing the inside, It's a mess. I'll get a new one even though they are close to $300 now.
Thinking of canceling my order for new stainless lines. When I pulled the old hoses off the front of the tunnel I found metal lines with barbed fittings! Not plastic. What's up with that? I've had this car since it was just 10 years old! '75 1.8 I bought in '85, had to be stock. Did porsche use metal tunnel lines? |
Apr 24 2023, 07:36 PM
They are plastic with a metal barbed fitting on the end.
Chris H. |
Apr 24 2023, 07:44 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Thanks all . . .. Got the tank out and after seeing the inside, It's a mess. I'll get a new one even though they are close to $300 now. Thinking of canceling my order for new stainless lines. When I pulled the old hoses off the front of the tunnel I found metal lines with barbed fittings! Not plastic. What's up with that? I've had this car since it was just 10 years old! '75 1.8 I bought in '85, had to be stock. Did porsche use metal tunnel lines? No sir, although I do get why you might think that. The ends are metal as Rich said. The later cars had lines that were made of a black plastic-ish material less likely to crack but at this age they should be replaced. |
Bruce Hinds |
Apr 24 2023, 07:51 PM
Thanks all . . .. Got the tank out and after seeing the inside, It's a mess. I'll get a new one even though they are close to $300 now. Thinking of canceling my order for new stainless lines. When I pulled the old hoses off the front of the tunnel I found metal lines with barbed fittings! Not plastic. What's up with that? I've had this car since it was just 10 years old! '75 1.8 I bought in '85, had to be stock. Did porsche use metal tunnel lines? No sir, although I do get why you might think that. The ends are metal as Rich said. The later cars had lines that were made of a black plastic-ish material less likely to crack but at this age they should be replaced. It does have the black plastic-ish lines in the engine bay .. .. |
Jamie |
Apr 24 2023, 08:23 PM
Senior Member Group: Members Posts: 1,031 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
Thanks all . . .. Got the tank out and after seeing the inside, It's a mess. I'll get a new one even though they are close to $300 now. Thinking of canceling my order for new stainless lines. When I pulled the old hoses off the front of the tunnel I found metal lines with barbed fittings! Not plastic. What's up with that? I've had this car since it was just 10 years old! '75 1.8 I bought in '85, had to be stock. Did porsche use metal tunnel lines? No sir, although I do get why you might think that. The ends are metal as Rich said. The later cars had lines that were made of a black plastic-ish material less likely to crack but at this age they should be replaced. The metal barbed ends are spliced onto the tank end of the plastic lines that go through the tunnel into the engine bay. I wish that the new tanks had been available when I had my original tank cleaned about 10+ yrs. ago and paid $350 for the service! |
technicalninja |
Apr 25 2023, 02:55 PM
$300 for a brand-new tank is DIRT CHEAP!
New early Datsun Z tanks are 700+ Modern plastic tanks are 600-1K. I know this as thieves can stick a K-bar style knife through them to steal your fuel because the anti-siphon valves really work... So, to save $75 worth of gas you lose 1k minimum as the thieves just knife them FIRST. Don't you just love modern technology... I would not allow any 50-year-old plastic/rubber anything to hold or transfer fuel, oil, refrigerant, or brake fluid, especially modern fuel under pressure. Way too many other chemicals have been in our fuel in the last 30 years for anything but metal lines to have resisted IMO. |
Bruce Hinds |
Apr 26 2023, 10:28 AM
Advice Taken - New tank and the new SS lines on the way. Always interesting when you get into one of these projects what you find. When I pulled the fittings off the bottom of the tank, the screen crumbled and the return line that had been capped off when I had done the conversion (37 years ago) was completely clogged.
Re-fitting the lines looks interesting, I watched the video and read some say how easy it is - we'll see about that. I am doing both since I'll probably go back to FI requiring the return. Where do the 3 "felt" pads go? I found 3 when the tank came out, but it was only evident where 2 were still stuck in. I did notice some paint worn off in two locations and I'm thinking of adding more padding. They are listed as being felt pads, but felt will hold moisture and they sure look as if they did. Would rubber be better? Also did a sway bar support repair. Years ago I'd done a half ass repair on one side where the nut plates had cracked out. So, I got the nut plate repair/addition kit from 914 Rubber so with the tank out, got my buddy Mike, the master with a MIG, to put those in. At that time years ago I'd put in a 911 19mm bar and made my own solid drop links which made a big difference in handling for auto crossing, I could even preload it a bit. I"m thinking now that the rubber bushed drop links would be better for the street and I should go back to those. |
930cabman |
Apr 26 2023, 10:34 AM
Advanced Member Group: Members Posts: 3,062 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Advice Taken - New tank and the new SS lines on the way. Always interesting when you get into one of these projects what you find. When I pulled the fittings off the bottom of the tank, the screen crumbled and the return line that had been capped off when I had done the conversion (37 years ago) was completely clogged. Re-fitting the lines looks interesting, I watched the video and read some say how easy it is - we'll see about that. I am doing both since I'll probably go back to FI requiring the return. Where do the 3 "felt" pads go? I found 3 when the tank came out, but it was only evident where 2 were still stuck in. I did notice some paint worn off in two locations and I'm thinking of adding more padding. They are listed as being felt pads, but felt will hold moisture and they sure look as if they did. Would rubber be better? Also did a sway bar support repair. Years ago I'd done a half ass repair on one side where the nut plates had cracked out. So, I got the nut plate repair/addition kit from 914 Rubber so with the tank out, got my buddy Mike, the master with a MIG, to put those in. At that time years ago I'd put in a 911 19mm bar and made my own solid drop links which made a big difference in handling for auto crossing, I could even preload it a bit. I"m thinking now that the rubber bushed drop links would be better for the street and I should go back to those. I purchased new SS lines from Chris (Tangerine) and kept them on the shelf for at least 2 years due to my hesitance to installing them through the tunnel already filled with plenty of stuff. Turned our to be one of the easiest projects to date. personally I sensed the "plastic" lines could go another 1/2 century, but changed them anyway. Leaking fuel is never good. |
jhynesrockmtn |
Apr 26 2023, 12:17 PM
I have done Chris's lines on two cars now and will do a 3rd soon. A bit easier with the engine out of the way but did my 70 with the engine in place. It does help to have an assistant in the car guiding the lines in the tunnel.
Bruce Hinds |
Apr 26 2023, 12:49 PM
I have done Chris's lines on two cars now and will do a 3rd soon. A bit easier with the engine out of the way but did my 70 with the engine in place. It does help to have an assistant in the car guiding the lines in the tunnel. I hope I can do it with the engine in. Mine is a SBC and everything is above the cross brace - I think the only thing else I may have in the way is a cooling line - we'll see how that goes. |
Chris H. |
Apr 26 2023, 06:28 PM
I did mine with the engine in. Should be no problem for you Bruce. Chris Foley's lines are a perfect fit.
Garland |
Apr 27 2023, 08:29 AM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
I did mine with the engine in. Should be no problem for you Bruce. Chris Foley's lines are a perfect fit. Just did mine this week, engine in, and right rear tire left on. No helper other than a borescope to see routing in the tunnel. (IMG:style_emoticons/default/white914.jpg) |
Bruce Hinds |
Apr 27 2023, 08:53 AM
I did mine with the engine in. Should be no problem for you Bruce. Chris Foley's lines are a perfect fit. Just did mine this week, engine in, and right rear tire left on. No helper other than a borescope to see routing in the tunnel. (IMG:style_emoticons/default/white914.jpg) Great Idea! I have a WIFI bore scope - Did you place it in the tunnel by the shifter facing aft, then looking aft from the front with the pedal board out? |
Lo-Fi Version | Time is now: 16th May 2024 - 06:59 AM |
