Fuel Crud, refinish fuel tank |
Bruce Hinds |
May 9 2023, 11:37 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Lines came in yesterday, looking at getting them in soon. I went with the 9.5 mm feed line and the 8mm return figuring I'll be going to FI at some point.
Question for those of you that have done this a few times - Feed first then return? What's the best way? No instructions were provided. |
Chris H. |
May 11 2023, 07:51 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Hey Bruce,
Just bumping this up to the top for you. It's been a LONG time (10+ years) since I did my lines and I had 8mm both ways, but the process is pretty much the same. I did not remove the engine, just lifted the car up fairly high. The nice thing about unequal size lines is you can't install them "backwards" (IMG:style_emoticons/default/biggrin.gif). They look identical but have different bends at the engine bay end, which is not noticeable until you're almost done. As I recall the only "hard" part was the fact that the lines have a bend at the fuel tank end so it took some wiggling and fishing to get them through the last bit. Also keep the rubber ends on them and put a little grease on them to help get them through the grommet. Of course I do not know the answer to your only real question, which line to do first....If you bought them from Pelican they were very likely Chris Foley/Tangerine Racing lines. I can't find the instructions I received with mu kit but maybe someone else has them? @ChrisFoley could maybe help as well. |
zoomCat |
May 11 2023, 08:56 AM
Member Group: Members Posts: 162 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
Lines came in yesterday, looking at getting them in soon. I went with the 9.5 mm feed line and the 8mm return figuring I'll be going to FI at some point. Question for those of you that have done this a few times - Feed first then return? What's the best way? No instructions were provided. Ian has a nice video of this, he did the supply line first. https://www.youtube.com/watch?v=IDFsZoI_W3g |
ChrisFoley |
May 11 2023, 11:08 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
.If you bought them from Pelican they were very likely Chris Foley/Tangerine Racing lines. I can't find the instructions I received with mu kit but maybe someone else has them? My products are not being sold by Pelican Parts at this time. (IMG:style_emoticons/default/smile.gif) |
rhodyguy |
May 11 2023, 11:14 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
It’s easier with the rear tires off if you’re on the floor. Take the seats out. Remove center console if equipped. When done with the tubing, put the tires on and Dr seat in and drive a bit to ensure every thing is good.
Bruce Hinds |
May 28 2023, 10:10 AM
.If you bought them from Pelican they were very likely Chris Foley/Tangerine Racing lines. I can't find the instructions I received with mu kit but maybe someone else has them? My products are not being sold by Pelican Parts at this time. (IMG:style_emoticons/default/smile.gif) Sorry Chris. I've been trying to spread the "love" through my project and give everyone that supports our teeners some support. B |
Lo-Fi Version | Time is now: 31st May 2024 - 09:05 PM |
