fuel tank pads, placement? |
Bruce Hinds |
Apr 28 2023, 01:46 PM
V-8 madness Group: Members Posts: 733 Joined: 27-December 06 From: Port Orchard, WA Member No.: 7,391 Region Association: Pacific Northwest |
Where do the tree pads go that the fuel tank sits on? I know of two, the one in front of or above the driver's feet (aft left bottom) and the opposite side but forward on the divider between the fuel tank compartment and the front trunk. But where does the third one go? When I removed the tank I just found it loose . . .
Also, has anyone used rubber rather than the felt pads which seem to hold moisture? The old ones are pretty nasty and were causing some rust. |
Lo-Fi Version | Time is now: 17th May 2024 - 05:59 AM |
