QUOTE(914sgofast2 @ Apr 29 2023, 10:42 AM)
I caution you not to use felt or any other material that holds water or moisture as padding, or you will have your gas tank rusting from the outside to the inside where it rests on the felt or fiber pads. Use a rubber pad that won't retain water or moisture. Grainger sells self adhesive EPPM rubber sheets that you can cut into the right size and shape. I think it's either 1/8" or 3/16" thick and self adhesive on one side. I bought some a few years ago when I discovered that my gas tank had rusted on the outside where it rested against the factory felt padding, and was weeping just enough gas to create a big gas smell in the passenger cabin.
Well said,looks like Mark @ "the house of rubber" (lol) is on to it as we speak.
I did mine with self adhesive closed cell refrigeration rubber insulation, easy .
My tank is pristine inside so no point in not doing it really,who wants leaks from outside rust !!!.
Cheers.
