Anyone running this intake ?, & Will it work with tangerine throttle linkage ? |
VolksSled |
May 3 2023, 08:48 AM
Newbie Group: Members Posts: 28 Joined: 3-May 23 From: California Member No.: 27,331 Region Association: Southern California |
(IMG:style_emoticons/default/poke.gif)
Hi New member here with a new to me bad ass 914 ( big /4) with webbers I just bought the tangerine throttle linkage To replace the home made linkage that was on there and did work well for a while I know that if it’s from tangerine it should be quality But I also ordered this induction from Germany Anyone have this ? (IMG:style_emoticons/default/beer3.gif) And will it clear the tangerine throttle linkage ??? https://www.thoro-tec.de/en/p/air-intake-sy...14-bulli-beetle ( & before I forget ) shout out to the cheap sob (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/wub.gif) Who I’m sure would be turning in his grave knowing I spent 999 euros on a intake ������ |
VolksSled |
May 3 2023, 08:49 AM
Uninstalled
Attached thumbnail(s) |
VolksSled |
May 3 2023, 08:55 AM
914
May 3 2023, 09:03 AM
1) change your name, its stupid and its 2023
2) stop advertising here. |
VolksSled |
May 3 2023, 09:13 AM
VolksSled |
May 3 2023, 09:14 AM
rhodyguy |
May 3 2023, 09:18 AM
Note the center pull linkage. Perhaps that’s what it takes.
BillJ |
May 3 2023, 09:22 AM
Senior Member Group: Members Posts: 1,098 Joined: 4-March 13 From: charlotte, NC Member No.: 15,610 Region Association: None |
So assuming you are just new and all...
I have not seen anyone post that as installed although i am.aware of and have bought thinggs from them. Will be interesting to see your impressions and please share. Also please do find out how to edit your name. It is offensive generally. |
rhodyguy |
May 3 2023, 09:35 AM
Most CASoB 914 owners don’t like dropping over 1k on airfilters that look kinda cool. I wonder how the conical filter flow compares to a set of plain paper filters for dual carbs. Is the filter pictured a ‘tosser’ or a ‘cleaner’ when it gets fouled? If a tosser, what is the replacement cost?
VolksSled |
May 3 2023, 09:47 AM
Most CASoB 914 owners don’t like dropping over 1k on airfilters that look kinda cool. I wonder how the conical filter flow compares to a set of plain paper filters for dual carbs. Is the filter pictured a ‘tosser’ or a ‘cleaner’ when it gets fouled? If a tosser, what is the replacement cost? I’m sure it’s a tosser |
VolksSled |
May 3 2023, 09:48 AM
Most CASoB 914 owners don’t like dropping over 1k on airfilters that look kinda cool. I wonder how the conical filter flow compares to a set of plain paper filters for dual carbs. Is the filter pictured a ‘tosser’ or a ‘cleaner’ when it gets fouled? If a tosser, what is the replacement cost? I’m sure it’s a tosser And I’m sure this is quieter then just air clearers on the carbs |
NARP74 |
May 3 2023, 09:53 AM
Senior Member Group: Members Posts: 1,065 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
I don't see how this intake can be any better than the std over the carb type? Unless it is just for the cool factor. Got any tests proving air flow?
+1 vote for change your name |
JamesM |
May 3 2023, 10:44 AM
Senior Member Group: Members Posts: 1,900 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Most CASoB 914 owners don’t like dropping over 1k on airfilters that look kinda cool. I wonder how the conical filter flow compares to a set of plain paper filters for dual carbs. Is the filter pictured a ‘tosser’ or a ‘cleaner’ when it gets fouled? If a tosser, what is the replacement cost? I’m sure it’s a tosser And I’m sure this is quieter then just air clearers on the carbs 1. Assuming its just the filter assembly it should work fine with the linkage, only issues you might have with the linkage are going to be around what throttle bodies are used. 2. If you really want to drop a lot of money on a cool/central air filter for a dual carb/TB setup I think these are the way to go https://www.ahnendorp.com/VW-Type-4---Porsc...d-Dellorto.html https://www.csp-shop.com/en/engine/air-boxe...ache=1683132184 |
sportlicherFahrer |
May 3 2023, 10:49 AM
Nothing to see here. Group: Members Posts: 1,079 Joined: 18-April 05 From: Tacoma, WA Member No.: 3,945 Region Association: Pacific Northwest |
The intake system appears to be well above where the cable system attaches and routes. Unlikely that the intake and linkage will interfere while using Weber carbs.
In regards to the filter, you could easily measure the one that comes with the kit and peruse the K&N catalog to find a washable replacement. https://www.knfilters.com/dimsearch As for your username, a private message to one of the admins ( @ClayPerrine and @SirAndy are currently online) can get that sorted. Clicking on one of their names will link you to the respective user profile. Communication options should be on the right side of your browser on the profile page. Current name is definitely not going to make many friends here.... |
VolksSled |
May 3 2023, 12:00 PM
Most CASoB 914 owners don’t like dropping over 1k on airfilters that look kinda cool. I wonder how the conical filter flow compares to a set of plain paper filters for dual carbs. Is the filter pictured a ‘tosser’ or a ‘cleaner’ when it gets fouled? If a tosser, what is the replacement cost? I’m sure it’s a tosser And I’m sure this is quieter then just air clearers on the carbs 1. Assuming its just the filter assembly it should work fine with the linkage, only issues you might have with the linkage are going to be around what throttle bodies are used. 2. If you really want to drop a lot of money on a cool/central air filter for a dual carb/TB setup I think these are the way to go https://www.ahnendorp.com/VW-Type-4---Porsc...d-Dellorto.html https://www.csp-shop.com/en/engine/air-boxe...ache=1683132184 I saw these before I pulled the trigger I’m just not a fan of the look and it costing even more |
JamesM |
May 3 2023, 12:38 PM
I saw these before I pulled the trigger I’m just not a fan of the look and it costing even more To me i think the main advantages of a shared airbox/filter would be 1. To keep water out of your air filters/carbs and 2. Reduce intake noise I dont really see that cone filter setup doing either of these, or anything other than significantly lightening your pocketbook. If anything if you have that cone pointed forward its just going to redirect the intake noise right at your head. and 1100 bucks for 3 3d printed pieces, a cone filter, and 2 silicone hoses seems like... a lot Price of the CSP unit appears to be the same (possibly less depending on current exchange rates) |
VaccaRabite |
May 3 2023, 12:43 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I just don't understand how that is a $999 euro part, and it blocks access to the oil filler. Also one cone filter has less dust catching surface then 2 carb mounted air cleaners - meaning that you are getting less airflow especially when the filter starts collecting dirt.
The big reason folks try to tie the throttle bodies together is to abate intake noise, but the cone filter pointed at the cabin is going to negate that too. So, aside from it looking kinda cool - what does it get you? Zach |
NARP74 |
May 3 2023, 01:40 PM
I just don't understand how that is a $999 euro part, and it blocks access to the oil filler. Also one cone filter has less dust catching surface then 2 carb mounted air cleaners - meaning that you are getting less airflow especially when the filter starts collecting dirt. The big reason folks try to tie the throttle bodies together is to abate intake noise, but the cone filter pointed at the cabin is going to negate that too. So, aside from it looking kinda cool - what does it get you? Zach This |
rhodyguy |
May 3 2023, 02:47 PM
I never found the carb sound obnoxious. Goes with the territory. Not much dif, IMHO, compared to stock FI unless your foot is into it and at a higher RPM than a 3k freeway cruise.
brubou |
May 3 2023, 02:57 PM
Bruce Bouchard Group: Members Posts: 92 Joined: 29-February 16 From: West Bradford, PA Member No.: 19,716 Region Association: MidAtlantic Region |
why is his name offensive?
Lo-Fi Version | Time is now: 17th May 2024 - 02:54 PM |
