FS Lots of Parts from shop cleanup, Bunch of Parts gotta go |
MrLeeS |
May 7 2023, 04:32 PM
Member Group: Members Posts: 62 Joined: 25-April 09 From: Albuquerque, NM Member No.: 10,300 Region Association: Southwest Region |
A Calipers, rebuilt. Had these done a couple of years ago for my track car, never used them. Checked them this morning on the bench. Includes hardware and new hawk blue pads cause that's what I used to keep the hardware together. $200
MSD Programmable 6AL-2 2 Stage rev limiter, boost/vacuum timing adjustment. Lock out your distributor and map your advanced curves. I used it with the Old CB quick tune injection on my turbo 914 since the CB spark control was useless in the ECU. I'll include the MSD3 bar map sensor and tach adapter to make it work with 914 tach (almost $200 themsleves), sold Raid Racemark steering wheel 360mm. Excellent leather, stitching is OK but there is some missing. Sold Snap-Gap valve lash setting kit, new. got it for setting 911 valves, but after receiving it and reviewing the instructions decided I preferred to do it the old fashioned way. Never opened. Sold Cookie cutter center caps pretty good shape. Sold Fuchs Center caps decent shape sold Cam Gears, 2 aftermarket, 1 OEM modified for bolt on cam $30 each Long Type 4 head studs ~1/2" longer than stock. I think they are old school raceware. Never used. stock 10 x 1.5 thread on head side. sold Mallory Unilite Distributor, new with extra new module spike protector and cap. sold 356 B/C Inside door pulls $75 Attached image(s) |
Lo-Fi Version | Time is now: 28th May 2024 - 03:51 AM |
