Turn signal trauma. 1973 wiring diagram? |
gnomefabtech |
May 8 2023, 09:55 AM
Member Group: Members Posts: 107 Joined: 27-December 22 From: Los Angeles Member No.: 27,063 Region Association: None |
I'm having a bit of trouble getting my turnsignals to work and can't find a legible diagram online. I'm bringing back a car that had a bit of rodent damage to the wiring so it's a tough one.
The setup is pretty confusing with the "parking light" function being added in. I have parking lights and blinking hazards but no turn signals. If I had a good diagram I could probably figure it out. Thanks. |
oakdalecurtis |
May 8 2023, 10:03 AM
Oakdalecurtis Group: Members Posts: 1,325 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Spoke |
May 8 2023, 11:12 AM
Jerry Group: Members Posts: 6,979 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Here's a simplified view of the turnsignals in the 914 w/o the 'park' function since the 'park' function has nothing to do with the turnsignals as it lights the running light in the front and rear turnsignal bucket.
Since you have 4-way flashers, most of your wiring is good. You need to check the wiring from the 4-way flasher switch to the steering column and the turnsignal stalk as well. Attached image(s) |
malcolm2 |
May 8 2023, 05:24 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
get you a laminated version from Prospero's Garage.
colorwiringdiagrams.com they are cheap, easy to read, printed by year, colorful and laminated. |
gnomefabtech |
May 8 2023, 05:30 PM
Thank you all for the great replies. I'll get back in there tomorrow and see if I can figure it out.
Lo-Fi Version | Time is now: 18th May 2024 - 11:54 PM |
