gnomefabtech
May 8 2023, 09:55 AM
I'm having a bit of trouble getting my turnsignals to work and can't find a legible diagram online. I'm bringing back a car that had a bit of rodent damage to the wiring so it's a tough one.
The setup is pretty confusing with the "parking light" function being added in. I have parking lights and blinking hazards but no turn signals. If I had a good diagram I could probably figure it out.
Thanks.
Spoke
May 8 2023, 11:12 AM
Here's a simplified view of the turnsignals in the 914 w/o the 'park' function since the 'park' function has nothing to do with the turnsignals as it lights the running light in the front and rear turnsignal bucket.
Since you have 4-way flashers, most of your wiring is good. You need to check the wiring from the 4-way flasher switch to the steering column and the turnsignal stalk as well.
malcolm2
May 8 2023, 05:24 PM
get you a laminated version from Prospero's Garage.
colorwiringdiagrams.comthey are cheap, easy to read, printed by year, colorful and laminated.
gnomefabtech
May 8 2023, 05:30 PM
Thank you all for the great replies. I'll get back in there tomorrow and see if I can figure it out.
