BUCKING, Clutch and throttle |
ctc911ctc |
May 8 2023, 07:32 PM
Senior Member Group: Members Posts: 892 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States |
'74, 2.0, 25K miles original (IMG:style_emoticons/default/biggrin.gif)
Spring is here and that means I will return to working on the car instead of looking at this beauty in my garage! The clutch is a bit bucky - may refer to this as chattering. New clutch and plate, HOWEVER, I did not mill the Flywheel - clutch and plate were original so I replaced them. I swear the flywheel looked perfect so I did not have it........... - yea I know, I know.......however, if anyone has other suggestions? As to the bucking from the throttle - I rebuilt: Throttle system throttle position sensor the vacuum plenum - it is tight! All hoses timing - right on plugs valve clearance all injectors near everything with the exception of the wiring harness......... the bucking is when it is in a low power between coast and starting to accelerate Runs great everywhere else on the power band. |
mgphoto |
May 9 2023, 07:22 AM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Bucking at low rpm is usually a distributor problem, I had the same issue, I went to the 123 dizzy problem solved.
Lockwodo |
May 9 2023, 07:25 AM
Member Group: Members Posts: 200 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
If it's bucking on acceleration with the clutch fully engaged, it's probably the trigger points in the stock disty. Second the motion to install a 123 disty.
ctc911ctc |
May 9 2023, 08:58 AM
May 9 2023, 09:00 AM
Clean and regrease advance plates in the distributor.
I would also remove and inspect the FI trigger points Rich |
mgphoto |
May 9 2023, 09:47 AM
If it's bucking on acceleration with the clutch fully engaged, it's probably the trigger points in the stock disty. Second the motion to install a 123 disty. 123 disty it is - however - what is a 123 disty - will ask the answer machine https://123ignitionusa.com/porsche-vw-bt-tu...h-programmable/ |
brant |
May 9 2023, 11:06 AM
Clean and regrease advance plates in the distributor. I would also remove and inspect the FI trigger points Rich (IMG:style_emoticons/default/agree.gif) |
ctc911ctc |
May 9 2023, 12:10 PM
StarBear |
May 11 2023, 08:09 AM
Senior Member Group: Members Posts: 1,884 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Any luck or progress? (IMG:style_emoticons/default/smile.gif)
ctc911ctc |
May 11 2023, 05:09 PM
Oh gosh no!!!
I work at a snails pace........ All of the parts on the car are in great shape (except the rusted ones which I replaced........I will most likely take it off in the next few days and rebuild it. Thank you, |
May 11 2023, 06:23 PM
I’m lazy and forgetful
Remove distributor cap Take a well lighted picture of the orientation of the distributor. Then pull it out, stick a rag in the hole gently You can only put it in one way, you cannot seat it 180 degrees off. But….getting the timing right is why I take a picture. Btw, I’m lazy Setting points perfectly is easier with the distributor in my bench vice (IMG:style_emoticons/default/smile.gif) |
ctc911ctc |
May 11 2023, 06:51 PM
Thank you Mr. Towle, the other guy from Taxachusetts
I’m lazy and forgetful Remove distributor cap Take a well lighted picture of the orientation of the distributor. Then pull it out, stick a rag in the hole gently You can only put it in one way, you cannot seat it 180 degrees off. But….getting the timing right is why I take a picture. Btw, I’m lazy Setting points perfectly is easier with the distributor in my bench vice (IMG:style_emoticons/default/smile.gif) |
May 11 2023, 07:10 PM
Thank you Mr. Towle, the other guy from Taxachusetts I’m lazy and forgetful Remove distributor cap Take a well lighted picture of the orientation of the distributor. Then pull it out, stick a rag in the hole gently You can only put it in one way, you cannot seat it 180 degrees off. But….getting the timing right is why I take a picture. Btw, I’m lazy Setting points perfectly is easier with the distributor in my bench vice (IMG:style_emoticons/default/smile.gif) Happy to help if you need any parts, tools, etc |
Lo-Fi Version | Time is now: 16th May 2024 - 07:15 AM |
